72" Mystic Catamaran build
Hello fellow boaters, I have a build im in the process of building a 72" Mystic Catamaran and installing dual inline twins, I'm needing advice on some good hardware to install, preferably a hardware package from a good online retailer. Or individual pieces. Either way I need to know all hardware I'm needing from top to bottom (drive, rutters ect...)
Thanks in advance my friends and happy boating*
Check the following website. www.gizmomotors.com/. Gizmo sells engines, hardwares, all that you need for your build he likely have.
If you are looking for a package of hardware to install a pair of inline motors into a 72" Mystic - there is no such animal. It is typically a matter of knowing what you are looking for and buying and modifying something to suit your needs. an inline twin build is an advanced build - something where you have to have a good handle on what you are doing - otherwise the lessons you are going to be learning are going to be expensive x 2.
I personally would recommend you look for something already built on the market or have one built (by someone with a wealth of experience with such builds) - while it lacks the DIY appeal it may save you $$ and time/frustration in the long run.
I dont like to recommend against learning how to do something - but if you are asking these questions at this stage of the build then chances are you might want to start with a single build and develop the skills and knowledge needed to save yourself some frustrations with a very complex build.
Very good advice in the previous post. Ok, I'm obviously not a nitro guy so I'm editing my post after seeing these inline motors the OP is talking about. But still, two total gas motors or two total medium-large brushless motors are more than enough to push a 72" cat beyond it's limit. Here's an MHZ 185 with two RCMK K30's. Do you really need more? And to qualify that question, I'm a guy who isn't satisfied with less than 700HP in a daily driven street car. So I like over-the-top, excess power...but in this case it seems like an over-complicated approach to do a twin inline setup.
Good morning and thank you for the valuable advice. This is not my first build, I built a mono vhaul with a zenoah 26 a few years back. This is my first catamaran build as I know there's different hardware to a cat vs a vhaul as I'm not familiar with. I decided to go with the twin inline set up because I like a challenge. This is no quick puttogether project. I plan on taking my time with this build and making it a beautiful piece. I'm open to all suggestions and opinions thanks again all my fellow RC"ers
