Go Back  RCU Forums > RC Boats > RC Boats General Discussion
Help !! on Build >
Help !! on Build
RC Boats General Discussion Discuss general rc boating topics here.
Help !! on Build
Old 08-07-2016 | 10:56 AM
Default Help !! on Build
Hi guys,
I am new to RC boat building although i done plenty of other RC modelling, Just puzzled on this issue need some advice & help with a dilemma please
I have a Commercial fibreglass hull of English East coast drifter from around 1918. The Hull length 47" Beam is 9" depth of hull 6.5" But hows the best way for me to work out the contoured shape of the bulk heads from the fibreglass hull i have, my plans are not to scale,
Old 08-07-2016 | 06:09 PM
All Day Dan's Avatar
I've used these for something similar in the past. Dan
http://www.homedepot.com/s/contour%2520gauge?NCNI-5
Old 08-08-2016 | 12:56 AM
Generally speaking, you don't need a lot of bulkheads in a fibreglass hull. Inwhales to fit the deck to the hull, cross beams to fit the deck to, the FG is generally strong enough to look after itself. But a contour gauge from the decorating section of any DIY store will do the job.
Old 08-08-2016 | 02:27 AM
Hi Bob1307
Scan the bulkheads from the plans and save them as PDF files.
Measure the bulkheads in mm's and to get to 6.5 inches(165mm) calculate the % difference and in the printer setup you can custom print to the required size.
Not allow for the fibreglass thickness.
The fibreglass hulls I use to make only required decking frames and a stringer around the inside between.
One of the customer's ask about the strength, so I weighted to the water line, lifted it to waist height and dropped it into the water!!
Dam nearly sunk but pop back up with no water in the hull and no cracks(no deck frames install at the test).
Old 08-08-2016 | 11:39 AM
Many thanks to all who replied. The hull i have is very well made so i see the point about fibreglass hulls been strong enough without bulkheads
Old 08-08-2016 | 03:46 PM
Hydro Junkie's Avatar
I'd still add at least two bulkheads, if nothing else, to minimize the possibility of flexing in the hull along it's length. While I agree with canabus in that they probably aren't needed, IF there's a thin spot in the layup, that is where flexing will crack the hull first. It is also cheap insurance against flooding the whole hull if something does happen and the boat starts taking on water
