World's Fastest EDF Boat???
I return you now to your normally scheduled thread content
Not really, if you know the reason behind it. That rule was installed four or five years ago when the forum started being slammed by people advertising their products in single post threads with lots of pictures. Next thing we saw was people had been swindled out of their money by these "advertisers" with no way of getting it back. After several complaints, the admins went through, cleaned out all of the posts that were clearly just for advertising a non-existent product, and installed the 10 post requirement. Needless to say, the problem went away almost immediately since the people that were putting the posts up now had to actually become an active member and that was something they didn't want to have to do.
3 down. 7 to go...
Then I will be able to share a picture of my EDF boat!!
Lovely weather we're having right now in the U.K.
StevKell (11-07-2021)
Lovely weather? What makes it lovely? In my neighborhood, we had scattered clouds and 29C yesterday
![Cool](https://www.rcuniverse.com/forum/images/icons/icon6.gif)
Go here, start a thread then make enough posts to meet the minimum.
https://www.rcuniverse.com/forum/test-posting-forum-72/
AFAIK there is no official “record” for EDF boats, just semi-official airboat speeds. That record is in the high-90s/low-100s but uses GPS speeds so not comparable to water-prop boats. I’ve heard a few folks mention EDF speeds in the 40s though.
BTW it was 43* here today…..
I have 43.43mph out of my scaled prototype. The full sized version (1.7x) is now fully ready to go which is designed to beat the airboat speed record. It's also an EDF. So certainly will be the fastest EDF if my prototype isn't already.
I guess I'll just have to wait and see if it gets contested.
I'd love to see your model, it sounds interesting. I've built many airboats over the past 50 years but only one EDF. I've held many official FE speed records with water prop boats and know the current world record holder very well (206 mph), but never tried seriously with my airboats because they were not recognized by any serious governing body. Perhaps I missed out.
The "official" airboat speed records were compiled by a fellow in Florida who ran an R/C airboat website and chaired the Radio Controlled Airboat Association (RCAA) but those have been closed down for years. The rules were that you used a GPS and had to video the entire run from turning on the GPS showing no max speed, making the run, pulling out the GPS and showing the max speed without any interruptions. Not the best method but for what he wanted it worked. Since there is no recognized governing body now, you can claim whatever you want. While the RCAA posted a top speed record of 70.4 mph, many airboats both fuel and FE have exceeded that speed since.
https://web.archive.org/web/20111017...peed%20Records
This is the fastest one I know of, but we are at the mercy of GPS and video and his integrity.
![](/forum/images/badges/premium_member.png)
I held one of those RCAA speed records for my .20 series SI3 3-point Hydro airboat with a Jett .35 BSE engine. My official record was 49.6mph I think which I bested a couple weeks later with 55.1mph. Not bad for a boat I scratch built with no true dimensions and wood I pulled out of a trash dumpster.
![Smile](https://www.rcuniverse.com/forum/images/smilies/smile.gif)
Thanks for the replies!
I got 48.41mph today on a test run with my full sized boat.
Only 50% throttle on the stick and it was still accelerating away. I had to throttle back as I ran out of lake.
I'm getting some lift at the rear which I'm adjusting for the next run. Quite lucky really as if it had not lifted up, I would certainly have not backed off the throttle and it would have ended up in the bank.
That’s a common mistake, running for speed on too small of a pond. Official SAW courses for water prop boats measure through 330-foot traps, plus run up and slow down room. The lake where many records were set was about 2000 feet long and accommodated speeds in excess of 140 mph.
Prop boats have a large wedge rudder and usually a turn fin.
But neither the fin or rudder have enough drag to really slow the boat down quickly. The actual braking is due to the prop. As the prop slows, the blades no longer are moving fast enough to push the boat so water that would have been drawn through the prop is now hitting the front surface of the blades, acting like a parachute and slowing the boat
Even with a water prop the boats will coast a long way without a turn fin, my riggers always did. In early FE days racers would use a car ESC with a brake which helped, but not in a long time since modern car controllers don’t have the amp capacity for a SAW boat.
A successful remedy for that has been the fitting of air brakes, several record-setting SAW boats have used them up to 140 mph. Still, the best solution is to run on enough water, which has its own challenges like wind and waves.
Got RPM (09-16-2021)
