kill switch ?
NJ
hello all
Being new to boats i've got alot of questions, this one is about a kill switch. Should I use a kill switch on the engine or just back out the idle screw and use pushing the trigger out (reverse) to kill the engine? If using a kill switch is feasible then how do you wire it? I have a close up pic of my engine in my gallery. Is the tab on the coil what I would use? Running a wire from the tab to the switch then to the block to get the ground? I think I would feel safer using a kill switch.
My Feedback: (48)
My European buddies run them. Maybe you can holler over at [link=http://www.xtremercboats.com/phpBB/viewforum.php?f=2&sid=2fe8a256ea3aca15605c493e46d4 85f0]Xtreme[/link] if this thread turns cold. Very cool guys.
NJ
Do you know if I was on the right track on how to hook it up? I think I will run one just to have a hard wired way to kill the engine. Better to be safe than sorry.
Use a kill switch, especially on a gas engine, my carb hung up (Shockwave) and that was the only safe way to stop it. Wire from hot side of coil to ground thru switch, switch will be off until you want to stop it.
NJ
rckid2002
There is a close up pic in my galley of the engine where you can see the coil. There is a tab comming out of the coil, is that where the switch would be wire from? It gets grounded to the engine case right?
NJ
OK, got it wired up. I use a micro toggle switch and mounted it in the red plastic cover on the back of the engine. Works great. I just like having peace of mind that I can shut it down with the flick of a switch.
NJ
Actualy, I was thinking of backing the idle screw out, setting the trim to idle, and using reverse to close the butterfly and kill the engine if needed. I think that would be less work than rigging another switch and less to worry about also.
