RC Surfer
#6530
RE: RC Surfer
Hello to everyone and thank you for all of the great information that I have been learning from. Unfortunately, I have done a very poor job of separating the many different ideas into what I should do with my new surfer. I am going to list my questions and or concerns and ask respectfully for a little assistance from the experts.
I recently bought a NQD Lisa off of Ebay... ( I know it is the lower end of things.. but it's a start for me.It won't be long before I begin shaping my own.)
In the mean time:
What is the best board sealing technique? Is it over kill to glass the whole hull? Should I use plastic filler in the deck screw holes? etc....
What is the best Lisa sealing technique? Has anyone sprayed her with "Stop Leak" rubber spray or similar spray sealing paint? Should I add spray foam inside of herfor strength or does that add too much weight?
What is the best Motor - ESC -Battery - Propeller and Radio combo for the NQD? I have read many postswritten over the years but I have yet to see whatis considered the new "standard" best way to go. (without over spending)
I know this is a lot to ask in one message but I am getting migraines trying to capture so manyideas from so many different places and times. I amhoping someone has the "newbie" list consolidated and up to date. If I could I would send it away and have someone do my initial setup. But, unfortunately I can not afford to do that. Plus I would get a lot more knowledge and skill development from doing it myself.
Thank you all that respond in advance,
In the mean time:
#6531
HI
RE: RC Surfer
long board dave
here is a link to sebs nqd he made that thing sing..
http://www.rc*********.com/nqd-mods-...mself-t58.html
bad billy is the guy to answers those questions
#6533
RE: RC Surfer
RC Resin ator- I would think that your 48" should be on around a 45 to 50mm prop depending on motor kv. Onmy 40"Ihave a 1.4 pitch 42mm dia.and1000kv motor. It is about right for what ican tell( I haven't used it very much).
Aloha, Karl
Aloha, Karl
#6534
RE: RC Surfer
longboard dave
If i knew then what i know now i would have split the deck..... instead i roughed up the plastic and epoxied strips of fiberglass along the seam.... filled in the screw holes to reduce rusting, better surface for deck seal to stick toand a better finish
I drilled a hole in the front for drainage as well but on the deck with a small rubber plug in it.
The rudder post cracked and leaked too so drilled out and glued a brass tube inside a little higher and epoxied around it to add strengthover where it cracked.
atm my engine mount bracket hasn't broken from the plastic yet but do have a foam block under front of motor to maybe reduce bounce when hitting hard.
you will prob have to change the propshaft/housing as well as many other things... would recommend BB or Surfcurl for more info too as they have done heaps of them
if it helps my one runs a 2400kv motor with a 3s batt atm... 3600kv with 2s would work..... the epoxy glue sticks better if you rough up the plastic.
just my opinion but i'm no expert.
bearcave
bearcave
#6535
RE: RC Surfer
[youtube]http://www.youtube.com/watch?v=BsCbdXROMi0[/youtube]
http://www.rcuniverse.com/forum/m_11...m.htm#11411721
#6536
HI
RE: RC Surfer
Watching Dom rc surfing Cape Town waves - make me want to head to SA with my toys.
Pity it is so far away!
Maui still has winter waves but it is just too windy & waves are totally blown out in most spots.
#6537
CA
RE: RC Surfer
Hugh,
Come here to San Clemente!!!
I had another 4 pack go out day........ Perfect size, max set waves were about 4 foot faces, but mostly 2-3 ft
Glassy and really fun. My new fin & linkage setup worked perfectly.
Special thanks to MJ for the fin.
InDaTube
InDaTube
#6538
RE: RC Surfer
We went down to Newport for a quick session, The conditions weren't great but got two battery packs in. My wife did a great job trying to film with a P&S cam since my camcorder died this morning. Nothing great but I got out for the first time this year.
[youtube]http://www.youtube.com/watch?v=JXXjmXo7vqg[/youtube]
#6539
HI
RE: RC Surfer
jra111
great sesion you got that board ripping ,,, you must have modified that board
it is fast and turns on a dime ,, it looks as good as sebs NQD,, are there any
secrets you what to share,,
indatube
save some of those waves for me,,
maui john
[/b]
indatube
maui john
[/b]
#6540
RE: RC Surfer
ORIGINAL: RC HAWAIIAN STYLE
jra111
indatube
maui john
[/b]
jra111
indatube
maui john
[/b]
Thanks John
Everything I did I learned from this thread about a year ago. Thanks for all the help guys.
I started with a Boardshark I bought back in 2007 then rediscovered it 2012.
I put in a flex drive, 3060 brushless, 120amp esc, 5000mah 3s lipo, and a lot of lead in the keel.
#6541
HI
CA
RE: RC Surfer
Hugh,
I don't quite know what to say......... I'm stunned that your GoPro mount works so well!!!!!
How in the world did you get the balance and stability worked out????
Have you tried it riding waves?
Thanks for sharing......... You the Man
#6543
HI
RE: RC Surfer
InDaTube - reality is that I have NOT got it all worked out ....yet
It seems quite stable while under power, view is ok for Big Waves - I think
I still have to work out quicker self righting - as GoPro keeps board from flipping upright when in calm water.....
Later.....................
#6544
CA
RE: RC Surfer
Hi Guys,
Well, I finished up my fin setup and linkage project.
Installed a brand new fin shaft tube with a slide in cross drilled bearing setup.
Then I customized a new steering arm that clamps onto the .25in fin shaft rod.
I also drilled the top of the rod and set in a threaded brass machine screw with the head cut off.
Now, I install the fin, clock it correctly, clamp on the arm and secure with the brass knob.
Even if the clamp fails, I won't loose the fin............ again!!!
New Saying......... I now do it nice cuz....... I lost'em TWICE !!!
Thanks MJ for the new fins.......
InDaTube
InDaTube
#6545
RE: RC Surfer
Hi allenthusiasts.... so many cats out of bags atm hard to know where to go seek look and enjoy these days
Hugh
that recent vision is certainly another way to film... 5 stars for you... niceto see silver surfer up and running again after the broken legs thing... must be a strongpuppy nowbeing able to be head held and walked from the sea to land hey lol... great stuff all good
maui john
in a perfect world i would have a miniature surfer with a cool board that surfs like a surferwith my head around the facthe rides a boat
in reality i have a bro/maui inspired halfcast 28" kyosho based foamy in progress...kinda hard to get the Hawaiin style happenin with Bro's realitys of fact but..... lol
Anyway here is a pic of my hybridbearcave 70 trip... posting progressin the oz ******** forum... andimo kites new siteis like the "********wikipedia" of modern times.
best regards to all and always checkin in bearcave
Hugh
maui john
#6546
HI
RE: RC Surfer
bc
dam,, your vision is beautiful so sleek yet still full in nose ,,, looks like a winner there ,,,
i see some bro surfer, and some maui rc surfer in your new board,,
indatube
your fin set up,, bullet proof ,, looks like you are ready for any thing
maui john
indatube
maui john
#6547
RE: RC Surfer
[youtube]http://www.youtube.com/watch?v=2lZaypw2cMs[/youtube]
http://www.rcuniverse.com/forum/m_11...m.htm#11435328
#6550
