RC Boats General Discussion Discuss general rc boating topics here.
RC Surfer
Old 04-15-2011, 08:03 AM
  #2376
RC HAWAIIAN STYLE
RC HAWAIIAN STYLE's Avatar
Default RE: RC Surfer
curly
with out lipo we would all be in the stone age . just like cananzi says nitros are a joke at our local track lipo cars are laping nitros, nimh bats have low run times and do not last ask any one that has both lipos and nimh bats. plus nitros have to get gas every 10 minutes lipo run time 15 minutes for the cars
mr fish i have used thrust bearingsit really smoths out the startup and saves the bearings in your motor . fish if you have to much power you can lower your timing on you speed controller that will lower power output and will run alot cooler and last longer. plus your run time is going to be 45 min. + dont give up on 4 cell, its all about run time my new surfer has a 45 min run time i am running 2400 kv 3 cell 5000 with a 120 amp speed controller the set up is just like cananzis but my surfer has more weight.
john maui PScurly , you must have alot of nimh bats you are allways trying to sell them to us . they are good for your flash lite but thats it
Old 04-15-2011, 12:48 PM
  #2377
itsfishi
thanks john ill do that timing low. can you please teel me a little more about your setup what size prop, what brand motor is that and what c rate are the batts you use. and is that a nqd kyosho or custum stick.the reasons i keep thinking ill go back to a 3s setup is batt size and weight. will be putting 6000mahs in on 4s where 3s i could get maybe 8000mahs. i think that you are spot on with the 2400kv on 3s some 26000rpm where i gonna have about 34000rpm with 2300kv on 4s which i think is too high(im gonna try it and see), i should have got 1800kv which will give 26000rpm, thats just something else to order. also are you using flex shaft and if so any tips for flex virgin.
45 mins is awesome runtime if i get that i will be so stoked.
cheers
Old 04-15-2011, 01:01 PM
  #2378
jocktime
jocktime's Avatar
RONKYTONK's Visit to Maui 04/15/11. Trying out one of our Maui********s.........jock
ID:	1594352   Click image for larger version
ID:	1594353   Click image for larger version
ID:	1594354   Click image for larger version
Old 04-15-2011, 04:30 PM
  #2379
surfcurls
Banned
Actually I'm out and Need To Buy Some... The Flash Light Biz has been Good ! LOL
Old 04-16-2011, 05:21 PM
  #2380
Kevinmham
Kevinmham's Avatar
Hi guys.
Been reading through some of the recent pages. A lot of info here ! There seems to be some grief with using the flexi shaft thing. I use dog bone drives on all my rc boats, including my surfer, with
100% problem free operation. I know that I don't run my board as hard or as often as some of you ( Jimi , you seem to go 24 hrs a day !!! good goin' man! ) but I do use this set up in my 28 inch Chris craft using a 775 motor and 11.1-14.8 volts and I bet it would probably run circles around any surf board !! I know it's a strong set up. How well it would withstand the stress of the prop repeatedly leaving and entering the water ( geting air ) , that I don't know . My set up has been in my board since last year and I am not particularlly easy on my surfer ! It's worked flawlessly.
Motor to shaft alignment is not as critical with this set up . The dog bone compensates for any error. Also, you need to move the motor ahead in the board to allow room for the new parts. This meant I needed less weight in the front , for my board anyways.
I've got a picture of the parts that I will post . The motor in the pic is not the one I use in my board, and I use a stainless shaft, not brass
Any way, I just thought I would offer a different system, in case no one was familiar with dog bone drives. If anyone else uses this set up, or knows why it shouldn't be used, let me know.
Surfs up !
ID:	1594825   Click image for larger version
Old 04-16-2011, 06:32 PM
  #2381
Cananzi
Kev
no problems with theGraupner semiflexi shafts and they are very affordable withthe whole setup up coming in under $30.
they are so smooth,Its the only reason i havent changed to anything else . I cant find anything that matches them for value.
$11 for the shaft
$13 for a coupler
$5for a screw on prop.
what sort of price is the dogbone set up? i had a simular one that i pulled from a boat but it had a skinner dogbone piece and i snapped it.
Old 04-16-2011, 07:04 PM
  #2382
Kevinmham
Kevinmham's Avatar
Cananzi
here in Canada, Great Hobbies on line has a 1/8 set ( 2 couplers, set screws, dog bone ) for $ 7.99 canadian. They are made by Dumas ( dumb- ass ? ) They also have a 3/16 set. I bought my stainless shaft from a local hobby
store, but forgot the price. $12-$15 maybee ? Maybe more. can't remember. Anyways, the brass collars are thick enough to redrill for different size motor shafts. I have even thought
about shortening a dog bone from my Associated RC 10 car ( they are made of steel ) if the plastic ones from Dumas were weak, but so far, no need to .
Oh yeah, for power in my board, I'm using a 3600 kv brushless motor on 7.2 volt NiMhs or 11.1 Lipos. As youcan see, i'm making good power, and the dog bone hasn't failed. What battery I use depends on what I have charged.7.2 volts seems to be fast enough to make it fun.
Like surfcurls mentioned, it's not a speed boat. I already have one of those. Also,if your board is the only rc boat-like thing you own, I can understand you wanting it to be as fast as possibleand using 3s Lipos.
They make killer power !
Old 04-16-2011, 07:09 PM
  #2383
Kevinmham
Kevinmham's Avatar
Forgot to mention my prop.
I use to use traxass screw on props ( from their Blast boat, I think, ) They were quick, but brittle and got chewed up by the somewhat rocky beach that I use.
Now I use a two bladed brass prop that I silver soldered a brass threaded insert into to make it screw on. It rules ! It's strong and has great speed as well !
Old 04-17-2011, 02:06 AM
  #2384
Cananzi
kev
The steel dogbone would do the trick for sure. My dogbone set up snapped when i aired off the wave and throttled it in the air and soon as it landed in the water it snapped under the pressure.
if you want screw on brass ,carbon or plastic props try http://www.cornwallmodelboats.co.uk/...ropellers.html
Thats where i get my Graupner semi flex shafts and props for my surfers.
Old 04-17-2011, 08:36 AM
  #2385
RC HAWAIIAN STYLE
mr fish
my set up is a ferigo short 2400Kv with water cooler, ESCseaking 120AMP, 3cell 5000mah zippy bat. and a high speed servo , prop X432 beryllium the X431 is good too. my board is only 18in. long and 6 1/2 in. wide it is really small to and its weight is around 3 pounds . i put a pic of a 37 in. and the yellow one is 18in. the big one is 4 cell run time 16 min. the small one 45 min. run time
john maui ps the trigger is very touchey on the small one ,i never go over 3/4 trigger
ID:	1595033   Click image for larger version
Old 04-17-2011, 08:45 AM
  #2386
RC HAWAIIAN STYLE
canazi
thanks for link i have been looking for that john
Old 04-17-2011, 10:25 AM
  #2387
Kevinmham
Kevinmham's Avatar
Hey guys
I broke my stock NQD bi-fin last week. Here is the replacement I made out of brass. It may be a little big, I don't know. Inever got my stock one back from the ocean to compareit to.
Tried it out yesterday. I think it works as good, or better, than the stock piece. The brass is stronger than plastic butthin enough todistort if it hits any rocks to hard
I see some other people use a single fin as well. What is the point of the bi-fin? If this info is already on this forum, sorry, I haven't read it all yet!
Old 04-17-2011, 02:37 PM
  #2388
itsfishi
thanks john. thats damn tight in there. and it is very light, i'll be weighing in around 4.5lb 2.1kg my 2300kv will be too much on 4s im sure. will hav to get 1500-1800 kv for sure me thinks. and itll be tight like yours, still waiting for all stuff to arrive to confirm it will all fit.
cheers
Old 04-17-2011, 03:42 PM
  #2389
Cananzi
john
those compartments are perfectly fitted.
fish
you might be ok on the 4s and the 2300kv. would look like a bullet at full throttlebut power comes in handy getting out in big surf tho thats for sure. cant wait to see how she goes man.
Old 04-17-2011, 03:48 PM
  #2390
ronkytonk
Great shots guys!!Thx for taking me out aswell. My wife cant believe I found some other RC nuts out here lol
I would like to get out again with you, again BIG THX,..you guys know what your doing. Even Karl's board shark version was unreal!
Call you guys tonite
Ronky
Old 04-17-2011, 04:17 PM
  #2391
Justin-san
Kevin
This is a shot of my fin. Its 1 1/2 inch long (its not the length its how you use it). I like the look of yours there is no base to it. I think the base and the gap under it is all drag. Yours looks like it has almost no drag. That should give more run time.
Justin
Old 04-17-2011, 04:26 PM
  #2392
Kevinmham
Kevinmham's Avatar
  Justin-san
   Mine is 2 inchs long.   Uhhhh........my  FIN,  I mean  !!   If the one I made is longer than stock,  maybe that's why it works so good.
Old 04-17-2011, 10:41 PM
  #2393
itsfishi
cana im gonna give it a go mate, just waiting on the postman. cant wait to have some vid to post myself.
cheers
Old 04-18-2011, 10:05 AM
  #2394
alien racing
Back from Anglet for the 1° French RCSurf Session !!!
Thanks to Lolocarrera forthis event... > Next time we gonna have to think about eating oisters and BBQ on the beach !!!
Some pics of the we :
Anglet Beach : Probably the best one for RCSurfin' in France !!!
The Magic team:
Here at work :
Troups transporter:
SomeDude :
And mine for my Baptism of Fire... Thank you Lolo
Old 04-18-2011, 10:44 AM
  #2395
surfcurls
Banned
Great Pics,
Looks Like everyone had a great time !
Old 04-18-2011, 07:47 PM
  #2396
jocktime
jocktime's Avatar
Alien Racing,
That was great to see, keep it up...........jock
http://www.maui********.com/index.html
Old 04-18-2011, 08:12 PM
  #2397
jocktime
jocktime's Avatar
Ronky,
Quick Video.........jock
[youtube]http://www.youtube.com/watch?v=IcoXHq82AXU[/youtube]
Old 04-18-2011, 09:15 PM
  #2398
Cananzi
Fellas
took both boards out today in 2-3ft shallow shoreys.
there seems to be something just not right with my dudette :-)
fiberglassed 4oz cloth snapped clean!! Snapped both legs!! lmao
Old 04-19-2011, 11:33 AM
  #2399
alien racing
Oh yes we had !!!
And especially me cause it was my first time in RCsurfin'... I will hope we gonna have other opportunities to redo it.
I have to say, I like RCsurfin' : It gives sense to halliday's beach !!! I will now do my best to prepare mine asap...
Old 04-19-2011, 01:09 PM
  #2400
Justin-san
Nice
