Radio help
Hi
My uncle is upgrading to a new radio for his plane. He currently owns a 9c futaba and he really gave me a good offer for it $200. Can i use this with boats?
Thanks!!!
Thanks!!!
FL
no, plane radios run on a air frequency and not a surface frequency....you will have to get a surface radio (one that operates on 75MHz or 27MHz)
heres a frequency list
http://www.offshoreelectrics.com/inf...freq-chart.php
sorry the model is ff9 maybe is the european version and on the manual it has 2 frequencoes 35 and 40Mhz. My uncle's one comes with the 35 frequency but is it possible to change it to 40?
In Cyprus where i live the frequency for surface is 40Mhz
http://www.rc-network.de/magazin/art...aender/CYP.pdf
My Feedback: (12)
SC
If it's the version that comes with a changable transmitter module, you may be able to buy one for the other frequency range. If it doesn't have the changable module, Futaba service has a program to replace the transmitter board. I know this service is available in the US, but I don't know where you would send it.
well i'm not sure but i think it will not be a good idea to risk it and up with a transmitter that doesnt work. I think i'll go for the futaba 3pk, what do you think about that?
OK
Pambs,
I have no idea what the requirements are where you live. But from what I've seen so far, that 'deal' may not be as good a deal as you'd think (wrong band). A multi-control-channel radio is very nice to have, all those 'extra' things you can control with it. But if don't think you'll ever need those 'extra' channels, or you aren't supposed to use it for what you want it for... oh well.
If you select a radio from a name brand, and if it has the required number of control channels, and if it doesn't require a trip to the bank before buying it, and if it satisfies all the 'other' requirements, then it ought to work just fine.
- 'Doc
Don't know about your's, but I have to watch my relatives very closely!)
- 'Doc
yeap same thing with the relatives here. Ofcourse my uncle's knowledge about surface frequencies is limited so i think he was just trying to help
Anyways i ve seen that a lot of guys in the US are using the 3PK or the react transmitters, what do you think about these 2?
I live in Cyprus which is a small island 1000000 people so the rc hobby is not that spread except when it comes to cars. but expensive receivers are not in stock so i'll be buying
one based on the info i get on the net
the prob is that i'll be building a large cat that will cost me a lot of money and i wont feel comfortoble without having a good radio if you know what i mean
thanks
thanks
GA
You can use the radio on 40MHZ for your surface vehicles. However, that is way to much radio for just about anything surface, unless you are talking about robots or highly detail scale models who need the extra channels. Tell your uncle I'll buy it from him for $200 bucks. I sold my 9C (ff9) last year and I wish I had it back for my aircraft....
~James
~James
GA
Cyprus is a small island off the coast of Turkey. 40MHZ is legal there for surface, thats why im saying he could use the transmitter for surface use.
My Feedback: (12)
SC
ORIGINAL: Pambs
OK
Pambs,
I'm not familiar with the 'React' radios at all so can't really say which would be better. Just because I'm familiar with something doesn't mean it's 'better'! In general, I think 'Futaba' is at the very least comparable to other manufacturers.
Having said that, having just one 'extra' channel sometimes comes in very handy! And since a 4 channel radio seems to be slightly more common than the 3 channels, why not? (Always keeping in mind that 'trip to the bank' thingy!)
As for receivers, the number of channels means very little as long as it has enough for that particular application. A two channel receiver will work just fine with a 4 channel transmitter as long as it's on the same frequency, uses the same 'mode', and is sometimes made by the same manufacturer (some do things differently). The other way around too, as long as the same "if's" are included.)
- 'Doc
- 'Doc
1 Post
ORIGINAL: saleens7
[link]http://reviews.ebay.co.uk/72MHZ-is-ILLEGAL-for-Radio-controlled-models-in-the-UK_W0QQugidZ10000000000948580?ssPageName=BUYGD:CAT :-1:SEARCH:2[/link]
