HOW TO SEAL a wooden hull?
I searched but I did not find anything specific about this, is there a tutorial or how to about sealing the hull of a wooden boat? with detailed pictures or instructions, I found several topics about this in the forums but none of them is detailed, what should I use to seal the hull of the Hamburg from Artesania Latina, how to do it? if anyone could help me with this I would really appreciate, thanks in advance.
My Feedback: (10)
RE: HOW TO SEAL a wooden hull?
hi
i am new to this but i just fiberglass my 5' pt boat with 2oz fiberglass and expoys turn out all right if yours is wood -mines covered in balas over wood ribs i would use lighter cloth, got a lot of help on the froums check all the froums in boats these guy really help out a lot all i have to do is give it a really good sanding then prime it, so dont be scare to ask any thing you want they will help u rye
I describe fiberglassing to novices as;
first prefitting and cutting the cloth,
then painting the boat with resin,
then smooshing the cloth into resin.
Then squeegee or press out the air bubbles.(I ususally just use rubber gloves and my hands to do this.)
[link=http://www.rcgroups.com/forums/showthread.php?t=329811]The best tutorial... .[/link]
[quote]ORIGINAL: Umi_Ryuzuki
Thanks a lot you made my day!
