Thunder cat engine shut down problem
hi there I have a problem with my grand new thunder cat again when I start the engine it working fine the smoke come out from the pile but when I put my thunder cat into the water it run about 10sec it shutdown the engine can anyone help me to solve this problem
RE: Thunder cat engine shut down problem
http://www.rcuniverse.com/forum/m_5944904/tm.htm
Since that is a new boat and probably not broke in yet, you will have to keep tuning it until it is fully broke in..... even then you will have to tune it every so often. You may also want to keep a few glow plugs handy since they do go bad sometimes, I usually replace mine on the last tank of break-in and evry 10th tank afterwards.
my tiger start is loose now I think I should order the pull start I want to know is this a right model numbers for thundercat Dynamite Pull Start Complete Mach 26, Mach 28 DYN0934
Mine had no problems and I just took it out this past weekend for break in.
Maybe you are running too lean and over heating engine.
Just follow the break in instructions for settings.
check to make sure you have no blockages in the fuel tank pressure line. If there is no pressure in the tank it won't run for long
