A question about chargers.
One of my chargers has a fixed charge rate of 4A and auto delta peak cut-off to trickle.
The instruction sheet that came with it says the charger is good up to 4000mAh batteries. That’s o.k as my best are 3300’s
One of my other chargers says up to 2000mAh as it only has a fixed rate of 2A before peak. Good for my 1500 and 2000 packs.
Long story short. I have been offered a great charger at a good price that has variable rate of charge from 0.5 to 5A but the packet says the unit is suitable for up to 3000mAh packs only. Although it is good for 4 – 24 cells which is why I want it so I can charge my 12 cells together for the 700 mono.
So at long last here is the question.
Can I charge a 3300mAh pack on a charger that says “up to 3000mAh” even though it will charge at 5A.
