Teflon tubing. What is it?
FL
The flex cable runs inside the teflon tubing much like a shaft runs inside a metal stuffing box or tube.The teflon tubing is flexible allowing for bends in the flex cable and is supposedly resistant to wear and self lubricating.[8D]
NB, CANADA
Spetz,
the teflon tube goes inside your brass stuffing tube.
now, if you were not using a one before than don't worry about it.
the majority don't use them anymore (except in outboards).
Dan.
Dan.
ah ok...
That makes sense
But now, if I buy a .150" flex cable which has the tubing...
Does this mean the outside of the tubing is .150" or is it the actual flex cable, meaning that with the teflon tubing it wont fit inside my .150" ID brass tubing??
That makes sense
ORIGINAL: sportygreg
I ran one of my boats all day and didn't pay attention to the shaft grease. Just kept filling up the "drip" oiler. Never again....spent an hour scraping the melted/twisted teflon tubing off that shaft. ALWAYS grease that shaft with your teflon tube. Trust me, would have been easier to make another shaft.
i just put a piece of fuel line on the end of the brass tube, lube always!!every 2 or 3 hours(i do it more then that[sm=punching.gif] because i freak out on what might not be PERFECT), and hell with the teflon
