dual rudder
hi yes i have tought about to but then there is the space, cost an time to fit to? all the ones i find have a shaft in them idid see one which was just rudders an bracket
I have no idea of what you're going to put it on but I've seen these Chinese setups before. The problem lies in that the hardware has to be mounted low on the transom but where the fun begins is when you have to mount trim tabs also as the brackets are in the way.
i dont want trim tabs i have never used them? i just want a bracket that splits an has two rudders on it, with no shaft built in to it, like the one i was told about
i have found this one at warehouse hobbies Complete SPD III w/ Dual Rudders Hardware Package, cant make out if i can just use the rudder an not the drive?
could I put a SPD III/dual rudder system on a electric shockwave 36 ,the electric motor is equal to a .71 glow engine so its powerfull but is that dual rudder just to much for that hull
