elecrtic motor testing
IA
I have a couple of 540's I need to test, Can I just hook them up to a 7.2 battery pack without harming them, or do I need to go through a speed controller? Thanks! Leisure Lake
ON, CANADA
Motor testing
You can just hook them up to the battery pack if you want to test them.
It won't tell you much, other than that they turn under power.
To find out what kind of RPM and torque they have will require a bit more elaborate set up.
Peter
www.climatemodels.com
Peter
If you have a mod motor, put an amp meter in line. You can dial it in for the best power band and least electrical using by watching the meter. Usually a 5 amp meter will work fine. I took one out of a fried battery charger or if you know of someone with a power panel that has gone bad.
CT
Elaborate testing
Grab the shaft with your fingers
Or, when testing, hold it when the airplane prop's mounted...ouch.
Or, when testing a CO2 motor, walk it up to your wife while running in your fingers. I'll bet she'll be just as impressed as mine was..... "Are you having fun?"
ON, CANADA
Impressed wife
Hey Rob,
Our wives must be related.
"And just what little toy are you amusing yourself with now? Never mind. Just go back out to your shop and play."
Peter
Peter
MA
Jay Turner once posted to use a astro whatt meter, an airplane prop and a airplane rpm tachometer to make a makeshift dyno. The problem for me is finding the right prop to get the current draw I'm looking for. It could be expensive trying out different props.
Steven Vaccaro
www.OffshoreElectrics.com
Steven Vaccaro
