Ist Time Boat Builder
hi all, this is my first post so please be nice if i make silly mistakes, i've spent the last year on and off building a remote control baitboat to aid my fishing. it's time hull with the bait dropper between the hull's. it has two moters for drive and i am going to use them independantly for steering. I'm running it on six volts as this boat not being built for speed. dimensions 2ft long 1ft wide and 6 inches high. it was float tested and with most kit on board it stayed afloat with three cans of soup, roughly 1 kilo.
my question is about electronic speed controllers, what ones??????
It depends alot on the motor amp draw, I like PROBOATS $40 ESC, its waterproof, is rated to take up to 40 amps continus, 6-12 volts, has a battery elimation circut, so you dont need a seperate battery for the reciever, has reverse, if you run two motors seperate you will need 2. Randy.
Cheers, is 40 amp the lowest i want to go? it won't be travelling more than 50 yds forward then the return trip, i would have put moter spec on but i sprayed them when i done the boat, stupid i know.
Any faults or idea's greatfully recieved
daz
daz
Important thing is what kind of motors and what kind of drive? In the UK have a look at Mtroniks, Electronise and Action-electronics. This last does a box with two ESCs and a mixer to simplify set up and operation, and is known to be generous with information and advice. A higher current rating is unlikely to do any harm other than to your wallet when buying as what will handle a lot will handle a little with modern (anything after 1980) controllers.
I ended up taking my boat down the local shop, got two 15amp esc, as i got the motors from the same shop they were able to identify them, got it all connected and took it down the local pond and man it was awesome seeing it run, lasted 10 mins before it stopped but good great fun.
