down and up thrust on airboat
It is the same on boats and planes. It is basically the angle of the motor or drive that makes it so you can vary it to adjust the running angle of the boat. If you use a pusher prop, tilt the back of the motor down to push the front down, up to lift the nose. It should be level most of the time, you can use other ways to adjust your CG to trim it.
