gas engine boats
gas engine boats
Hi All,
I am interested in RC boats using zenoah or similar gas (weedeater type) engines. Can anyone out there point me toward some companies that provide such a boat/engine outfit?
Mike
Mike
gas engine boats
Here, try these. Don't forget to have your checkbook ready!!
http://www.ballantinehobbies.com/
http://www.whobbies.com/
http://www.aeromarinerc.com/
http://www.pratherproducts.com/
http://www.bonzisports.com/
http://www.marinespecialties-rc.com/
http://www.expresscraft.com/
http://www.mhz-engines.com/
That ought to keep you busy for a while.
gas engine boats
Here's another to keep you busy when you get bored~
http://www.modelgasboats.com/Home/Re...rce_links.html
RE: gas engine boats
Hello I'm building a 67" Catamaran very shortly and intend on using twin weedeater or chainsaw engines my grandmother sells Husqvarna, Shidawa and the sort but the problem is she lives quite a ways away so I've been looking at alternatives such as poulan and troybilt. I would really like to go with the Zenoahs or quickdraws but I don't have the coin for such an expensive motor like them I know they're worth it because the work is done for you already but for now I think weedeater engines are the way to go for now. So my quetion is which brand should I go with as a starter motor? I'm building the Cat from scratch I have the resources to do it since my dad builds boats for a living but I'm stuck on which brand of weedwacker engine to go with? Everything I've looked at so far is in the 25-30cc range and are reasonably priced which really attracts me to them. So your advice as to which brand is good would be greatly appreciated! THANKS!
IL
Here's one
http://www.aquacraftmodels.com/boats/aqub43-main.html
Have fun!
Russ
Have fun!
Russ
ORIGINAL: Zman-RCU
Hi All,
Mike
Hi All,
Mike
TM928, I'm biulding a custom 75 inch deep vee, and I plan on running low cost twins in it. Picked up a pair of bolens 31 cc weed whackers, with a lil expeirmenting we realized that changing out the carbs to some that has adjustable high-lows and welding up a sufficient tune pipe we could make those babies scream. No water testing as of yet but will post pics as soon as I do..Low cost as of 69.99 a piece @ loews............GOOD LUCK, you don't always have to by the most expensive....
