Help with boat
I have never been into boats before, the only reason i am into them now is because i have to build one for my composite materials class. The boat is about a 1/10 scale or maybe just a little bigger. I have no clue what so ever on what motor, esc, prop, servos, rudders, shafts or anything that goes with them. if anyone could help me out a little bit it would be greatly appreciated. I also have another post called best motor but i put some wrong info into it. thanks for your time.
well i dont really know what its called... what i think its a hydro? its about 30 inches long, the front of it does a spear thing that looks like a 3
NB, CANADA
that is a rigger.
do you have some dimensions?
are you going to have the front sponsons and the rear ridding pods all molded to the body in one piece?
Dan.
Dan.
How old is that mold anyway? My guess would be that it's got to be maybe 30 years old.
It's an outrigger hydroplane.
What the length is will determine what size motor that you're going to need but plan on emptying a wallet or two to get it on the water. As outdated as that design is, don't expect a lot. You've got a lot of work ahead of you once you get the hull laid up to the getting it wet stage. Try to fill the sponsons with foam floatation before joining the hull halves together.
BTW, in this type of hull, there is no scale as there aren't any full-sized boats that look like it although a few have tried with mixed success.
