Traxxas Spartan jet drive buid
So i thought i'd share the the jet boat build with yall. I have this thread on traxxas forum as well.
Recently, i went to garner state park in east texas for vacation and i loved the rapids so much. Now i want to go back but with a boat that can handle rapids. So i found a Traxxas Spartan shell for $20 local and the guy threw in a free tqi tx! Great deal indeed! (especially since my traxxas link tx just died on me :( ). It paired right up to my traxxas link rx and im happy again. So the plan is to use the vxl-6s combo with a KMB 28mm jet drive. I'm only doing the KMB because it doesnt cost $400 like the graupner or HK. I plan to run two trx 7600 mAh 2s lipo in series for 4s and then later i will go to 6s. Since it's jet drive, i wont need the prop or rudder stuff ;). I still plan to use turn fins (stock), and the trim tabs (cnc machined ones). I will somehow make a couple of http://www.offshoreelectrics.com/ pickups work for cooling. But anyway, Here's my blank canvas: http://pic20.picturetrail.com/VOL146.../409778679.jpg I also plan to build or buy a nqd tear into jet boat but that would be after this build for my 11 y/o brother to do rapids with me, |
Ok dropped the idea of the 540xl with the esc cause of the price. Instead I am going to get the Turnigy 3720 1500kv outrunner motor with water cooling. I also noticed it has 3.5 mm bullets so i'm gonna have to get 5.5mm bullets to solder onto the motor. It should save me $100 right there. I also plan to use two dual transom mount water pickups as trim tabs since i dont need trim tabs that much and the extra couple of pickups will make a interesting rooster-tail at top speed (which will be 30 max). I also have a goal to completing this build. I plan to run the river at New Braunfels and i want to bring it if its complete. If not, then that's fine. I have a few fresh water spots i can run at.
Ok so found an even better designed jet drive by Mickieb from Offshoreelectrics.com. It's a 30mm jet drive unit that has a 3 blade machined impellar which is much better quality than the kmb jet drive. I have also found that it will be best to mount a jet drive on a flat spot rather than the V shape. So i will be cutting about 8 inches off the bottom of the boat. It will be an angled cut so as to not cause cavitation. I am not sure what material i will use yet to fill it and make a spot for the jet drive. I have some sheet metal in the shed and i believe that could work but wont know until i get some definite dimensions of the jet inlet. I also found a motor that will work without soldering on the vxl-6s esc and i will be using it. It's a 1790kv motor. So on 4s, it will be close to the rpm max of the jet drive unit. Should be good for the price.
Originally Posted by ManDime
(Post 11845397)
I have also found that it will be best to mount a jet drive on a flat spot rather than the V shape. So i will be cutting about 8 inches off the bottom of the boat. It will be an angled cut so as to not cause cavitation. I am not sure what material i will use yet to fill it and make a spot for the jet drive. .
Thanks for the heads up. The carbon fiber came in friday and i will be making the cut today if i have time.
Here's how the carbon fiber sizes up:
http://pic20.picturetrail.com/VOL146.../409860350.jpg I'll use the extra to plug the rudder hole. I wasnt able to work on it tonight but i will tomorrow. |
Sorry i havent updated yall but if you want to see the build then feel free to look here: http://traxxas.com/forums/showthread...jet-boat-build
Almost done!!! |
