RCU Forums
-   RC Boats General Discussion (https://www.rcuniverse.com/forum/rc-boats-general-discussion-77/)
-   -   calculation program, fluidynamics (https://www.rcuniverse.com/forum/rc-boats-general-discussion-77/5463149-calculation-program-fluidynamics.html)
TRCX 02-23-2007 01:16 PM
anybody know of a free program which can be used to calculate what type of wing would be needed for a hydrofoil (boat)
BMatthews 02-26-2007 08:25 PM
RE: calculation program, fluidynamics
Wing sections in water work a lot different from air wing sections. I'm moving this to the boat forum where you should be able to get a better answer.
Umi_Ryuzuki 02-26-2007 10:19 PM
1 Attachment(s)
Hydrofoil surface area Formula
You need to estimate the area needed, so get out your calculator. The formula is:
S = L / F U² Cl
S = Surface area in Square feet
L = Lift (this is the total weight of your boat, crew, etc., in Pounds)
/ = "divided by"
F = Factor to adjust for water density, unit measurements, etc. Use the number F = 2.09
U^2 = Velocity in MPH multiplied by itself (squared)
Cl = Coefficient of lift. See the table provided below for Cl. You should cruise at a high L / D or say 2.25degrees.
Take off will be at a higher Cl & lower speed. You must make some assumptions based on experience.
[edlt]
oops forgot the table....
DONS BOAT WORKS 02-26-2007 11:25 PM
Umi = Ultimate math instructor.[8D]
