Threads Grub screws and Prop shaft's
Hi there What thread are the normal small grub screws?? because im looking into making my own motor>shaft connectors and how could i make a prop shaft if i have the inside what could i make 4 the outside bit of the shaft?
Thanks all JJ:D:D |
RE: Threads Grub screws and Prop shaft's
some are metric, some are U.S. standard. U.S. Standard can be 4-40 or 6-32. Not sure the sizes in metric.
for metric sizes, its not unusual for shafts to be 4mm diameter
Try building your stuffing tube similar to these suggestions...
http://www.rcuniverse.com/forum/m_46...tm.htm#4691539 You can vary the shaft size, tube size, and even substitute some real bearins or oilite bushings if they are available. [8D] |
