So what really sets one engine make/model apart from another?
#176
Looks pretty good to me - interesting to see the difference between the LST manifold and the 41017.
How does the Boost .28 compare to the P3 in overall power and timing? Box stock that is - I know the modified engines are often quite different from stock.. Not fishing for trade secrets here; just curious about stock P3 vs. stock Boost version.
#177
#179
Me too. Given the length, it makes perfect sense that it makes so much bottom end. I noticed a huge increase in top end when I swapped the long losi manifold for the 41016. The engine temp dropped significantly with the shorter manifold too. That makes sense too given the timing of the engine. I ran my P3 today for quite awhile and it runs really well. My big heavy LST ran pretty close to a stock brushless slash 4x4 on 3S. That surprised me.
#180
Ok I have a question, Everybody talks about the 086 pipes. The thing is that most of these pipes are discontinued. the only one that I know of that is available, still being produced, is the Novarossi 9886 which is an 086 pipe. Yes I know that you can still get some of the other 086 pipes and ebay and such, and that most of the 086 pipes are relatively the same but that's not what I want to know. So what I want to know is how are the new style pipes that are offered today? Do they have better performance? What is a good mid-high pipe like the 086 was? Do they offer a new in production pipe that is of better quality and performance? Why should I track down an old style, discontinued 086 pipe if the new style pipes are better? By the way I did purchase the Nova 9886 and I do have the Dynamite 086, They are basically the same pipe.
#181
Basically, most 086 pipes from the past were essentially copies of the Nova 9886 as I understand. Some were poor copies, others were pretty good. The Dynamite 086HS is said to be pretty close to the 9886 Novarossi. Most of the other 086 pipes just fall short in performance and tractability compared to the Nova - which is why guys in the know get the Nova pipe.
Dyno tests have shown that A) the 9886 pretty much walks on most other pipes in terms of total power potential and B) the manifold can have a more poignant effect on power and its curve than the pipe does. Conical manifolds produce more power than tubular manifolds do.
Neal at the nitro shop has done dyno tests using either a 41016 or 41017 manifold and 9886 pipe and found nice horsepower gains over longer tubular manifolds on a modified off-road engine.
#184
I found a Dynamite pipe without header on eBay for $25 new in box. If you're set in an 086 pipe and want to do it as close and cheaply to the 9886 Nova, that's your best bet. I have both the Dynamite 086HS and Nova 9886SS. Both look very similar, but the stinger bore is larger on the 9886. I'll run the 9886/Legend 28-8 this spring to compare the two pipes.
I dont race, so all out power and speed work for me.
#185
On a whim, I'm going to try a Turbo head button in my pullstart Picco .28 P3. I was told the head button from the Schumacher X28T is basically the same internals as the P3 .28 Turbo engine. Schumacher pn: pp2347. I found it for about $22USD shipped from the UK. I'll try it out along with some turbo Picco plugs - P6TC and P6TH. I'll get a couple of each and see which works better. It's in an LST2 basher rig. I'll compare running characteristics against the standard P6S plugs I've been using in it. I may try a Novarossi C6TGC plug too if the taper is the same since I have a whole card of those too. Probably all overkill in a basher, but in the event it isn't what I want, I can sell it.
