slalling when brake
my car stalls when braking its not the idle gap changed clutch last time it worked this time it has not should I chane thi spring possision its 2 pice clutch with spring on the outer side all way round
The clutch spring either broke or the ends came apart. If it didn't, you might need to reverse he shoes so they face the other way in case they're engaging too soon.
what if there the wrong way it will stall when brake. it can just be ticking over not moving and I brake it will cut out
Originally Posted by bram321
(Post 12064844)
The idle screw maintains the minimum idle speed. |
| All times are GMT -8. The time now is 01:22 AM. |
