Lrp.30 problem
Old 10-13-2010 | 10:04 PM
Default Lrp.30 problem
Hi guys, I broke the head button on my lrp.30 . the part where the glow plug screws in at, & wanted to know if I could use any other head button on my engine ? I have other engines laying around like the ofna.32 or the stock 4.6 motor , my question is can I use any of those button heads om this engine ? if not other then just getting another lrp.30 head are there any other heads I can use ?
I guess I screwed up the patterns inside the button head..........the 4.6 head looks like it will fit- have anybody ever came across this problem before and if so what can I do ????
Old 10-14-2010 | 10:31 AM
My Feedback: (12)
Default RE: Lrp.30 problem
To my understanding head buttons are engine specific.
Old 10-14-2010 | 02:03 PM
thanks
Old 10-15-2010 | 08:31 AM
The only way to know for sure is try each one, cause i did that before and sometimes different head buttons will work. Hit me up i left u a message on Youtube with my new number.
Old 10-15-2010 | 09:20 AM
Got you "DEVO" ! I'll call you around 3pm today..
Old 10-16-2010 | 05:37 PM
Anthoop's Avatar
http://www.rcuniverse.com/forum/m_10072419/tm.htm
You will need to use the correct part, even though some head buttons from other engines may fit it is unlikely the actual head volume and squish band is identical.
Old 10-16-2010 | 10:08 PM
I'm not sure but tonight I used a button head from either my axial.28 rr or my stock 4.6 motor on my Lrp.30 engine . I'm happy too ! Not sure How it's going to run but the damn thing started right up on the first pull............ I'll check it out tomorrow.
