bent dogbones :-(
so the front right dogbone got bent idk how it happend.I put a really small piece of fuel line in there I hope that wasznt the reason why. Any upgarded stronger dogbones for the tornado s30 out there.
Redcats are very cheap...I also use Team Associated ones from a t1 or 2. Sorry no part #. Plan on replacing these very regularly...I have replaced 6!
i knew there had to be some that would work. i recently tried some T4 dogbones, but the pins where to fat to fit in the drive cup slots.
will have to pick up some t1 and t2 dogbones and see which of the 2 work.
http://www.teamassociated.com/search...ts=20&search=1
They have so many.. but the don't say t1 t2.what should I do.do u knw how long they are? 85mm?86?
My Feedback: (42)
CT
Ah just throw it in a vice for now, that will get you running until you find something stronger. Just make sure the piece of tube you put in will still allow full suspension movement up and down, without binding.
