Stearing
Does your car have an integrated servo saver? If it does, it may be loose. There should be (if your car has one) a little adjustment knob looking thing on one of the steering posts, tighten that a little and see if that helps. Also, make sure your transmitter is adjusted right. Depending on your transmitter, there should be a knob or wheel that adjust the throw, also make sure your EPA is adjusted right. Look in your manual to see how to adjust each of those.
Haha it's always the simplest words, too.
ORIGINAL: electricrc68
OH I GET WHY THE E's ARE UPPERCASE NOW!!!! took me a while......
<br type="_moz" />
ORIGINAL: HimmlerHimself
Check you stEEring exponential.
<br type="_moz" />
