Digital Servo. Programable??
Old 05-28-2011 | 03:26 PM
Default Digital Servo. Programable??
Ijust picked up one of these servos for my MGT. Ihad a HiTech that worked great but it was glitching my other servos after awhile.
Anyway with this servo i have less steering then i had before.
The box didnt have any directions in it and the tech at the LHS is on Vacation.
Old 05-28-2011 | 04:15 PM
SyCo_VeNoM's Avatar
Default RE: Digital Servo. Programable??
try to adjust your D/R, or endpoints (dunno what radio you use)
Old 05-28-2011 | 05:32 PM
proanti1's Avatar
I have this one for my hitec servos.
http://www3.towerhobbies.com/cgi-bin...?&I=LXWCE9&P=7
There is really no need, as you can do most of the adjustments with your transmitter. You will not be able to speed up the servo, but you may be able to make it travel further. Most Hitec digital servos have integrated fail safes, and you can set those with the programmer. The one I posted also works for most other digital servos (except some old Futaba ones).
Old 05-29-2011 | 06:50 AM
My hitech was a power hog. 3 tanks and i would lose all power.
Whats D/R??
I took off the servo saver and im just using a horn now which has more movement But im having alittle problem with that because the way the teeth line up arnt close to being center so i gotta have the controller setting all the way and i have good steering 1 way but the other way the servo is maxed out because of the controlller setting.
Old 05-29-2011 | 08:12 AM
tommygun32's Avatar
From: San Diego but living in Dubai, UNITED ARAB EMIRATE
What transmitter / receiver are you using?
What receiver / servo battery are you using?
Old 05-30-2011 | 06:47 AM
ORIGINAL: tommygun32
Team Associated 2.4 with a battery pack and a hump pack battery in the truck
