Fantom Engine
Old 08-15-2003 | 04:07 PM
T-Maxx_CA's Avatar
Default Fantom Engine
I found this fantom engine on EBAY and was wondering if this engine would work in my original RS4. Thanxs for your help.
http://cgi.*********/ws/eBayISAPI.dl...category=34062
Old 08-15-2003 | 04:09 PM
T-Maxx_CA's Avatar
Old 08-15-2003 | 04:10 PM
It should. I have the same one in my rs42. I just had to change my throttle linkage
Old 08-15-2003 | 04:14 PM
please post just the auction number... links are destroyed here...
Old 08-15-2003 | 04:24 PM
T-Maxx_CA's Avatar
The item number is 3142213090. Thanxs for the help.
Old 08-15-2003 | 04:55 PM
Well, it should work, but keep in mind that is a non pullstart engine, so make sur eyou have a flywheel, engine mounts, and bump starter...
Also, the stock pipe onthe rs42 might really put a choking on that engine...
Old 08-15-2003 | 07:28 PM
T-Maxx_CA's Avatar
could u put a pull start on this engine?thanxs
Old 08-15-2003 | 07:35 PM
Well, I'm sure you could.... Easily/Cheaply? Most likely not...
Old 08-15-2003 | 08:18 PM
Nitrofreak where did you get your throttle linkage from? I had to make my own because i couldnt find one. You hav a li nk or something? thanks
Old 08-15-2003 | 10:36 PM
I just used ONFNA linkage Part#10725. It is standard linage instead of the servo saver that HPI uses
