Ghetto diff gasket material??
Old 10-28-2011 | 02:38 PM
Foxy's Avatar
Default Ghetto diff gasket material??
Hi guys, I disassembled my Savage diffs to check and oil them, without checking if I had any spare gaskets. Turns out I don't. Is there anything else that works in a pinch as gasket material? I'm due for a bash tomorrow, so any ideas would be awesome. Ta.
Old 10-28-2011 | 03:07 PM
Default RE: Ghetto diff gasket material??
I would imagine in a pinch you could just make your own?
Head to your local auto parts store and get the thinnest gasket material they have, it's usually sold in sheets.
Old 10-28-2011 | 03:12 PM
Foxy's Avatar
Dunno if I'll have time to get to the store. I might try to get down to the LHS early and see what they've got, but if I don't make it, I was windering if there was anything in the house I could use. I was actually thinking used decal sheet might work just for the day.
Old 10-28-2011 | 06:20 PM
ORIGINAL: Foxy
As in the back side(paper) of it? That or use poster board. Or thick cardboardy paper.
<br type="_moz" />
Old 10-29-2011 | 01:36 AM
redfisher1974's Avatar
Phone book cover....
Old 10-29-2011 | 02:55 AM
Foxy's Avatar
What about a bathroom silicone sealant?
Old 10-29-2011 | 04:23 AM
Sure why not.
Old 10-29-2011 | 04:42 AM
Foxy's Avatar
I tried it. So far so good. If it works I'll probably always do this instead, should be a better seal even than a gasket.
Old 10-29-2011 | 06:55 AM
Buy a tube of ATV gasket maker from the auto store. Will last a long time.
Old 10-29-2011 | 07:27 AM
FahrtAutoRC's Avatar
I use the same silicone gasket maker we use on 1:1 cars' oil pans. Works great, just gotta give it time to set up!
Old 10-29-2011 | 07:33 AM
Foxy's Avatar
Time to set up? I just daubed it on the ring gear and slapped it together. [&:]
Old 10-29-2011 | 10:57 AM
The Mad Modder's Avatar
ORIGINAL: redfisher1974
You mean RTV?
Old 10-29-2011 | 10:58 AM
ORIGINAL: Foxy
I think he means before you run it.
Old 10-29-2011 | 11:38 AM
ORIGINAL: The Mad Modder
You mean RTV?
Right you are.
Old 10-30-2011 | 02:08 AM
Foxy's Avatar
ORIGINAL: Foxy
Ah, ok, that's cool, it's been at least 24 hours already.
Old 10-30-2011 | 06:06 AM
1QwkSport2.5r's Avatar
I dont know off hand the exact arrangement of the ring gear and diff on a Savage, but If its a bevel gear anything like the Losi LST's, the thickness of the gasket can effect the pinion contact with the ring gear. You might have to shim the diff differently.
I make my own gaskets for all sorts of engine parts. That is, if they used paper gaskets in the first place. If there were O-rings, I'll retain O-rings and use Ultra Copper RTV. Paper gaskets always get a thin film of UC RTV on both sides of the paper and assemble parts immediately. The best paper I've found for making into gaskets is 50-70lb white cardstock. About the same thickness as Index cards. When I make "ghetto gaskets", I cheat. Stick the cardstock in the AIO printer, and stick the part I need a gasket for on the scanner bed with white paper covering the rest of the glass. Gives me a perfect image of the near-exact size of the gasket needed.
I need to get a hole puncher that makes teeny holes instead of the standard size hole puncher for the screw holes. I need to make some backplate gaskets for a couple airplane engines I have and cutting screw holes with an X-Acto knife takes forever.
Old 10-30-2011 | 07:17 AM
Lars from Norway's Avatar
I have in fact used milk carton as the bottom gasket on the cylinder on the moped i once owned! Impressive that it held up for some days.
