engine power
Someone on this forum was going to "hone" his head and piston sleeve for more horsepower. In theory, it should work but you would have to be very careful in not taking off to much. But I've only seen it work on a ringed piston. You might be better off just getting an ABC kit for your engine. If you were refering to porting, then that is something more common. Although, I would get that done professionally. Try doing a search and see what you come up with. But if you want my opinion, there are easier ways in gaining more power other than this.
