engine question
ORIGINAL: rooker
Are there any engines besides Traxxas that have an electric start?
ORIGINAL: proanti1
Basically just Losi and Traxxas in regards to RTR models. You can use the Traxxas EX-Start with several aftermarket engines though, including a few Novarossi engines, OS, and Dynamite.
ORIGINAL: rooker
My Feedback: (27)
Check out the Sullivan Tiger Drive. You can get the for many different engines and brands. Here is a link for a list of the engines they work with. Hope this helps!
http://www.sullivanproducts.com/Prod...xMainFrame.htm
ORIGINAL: rooker
I have a VERY bad back. The EZ start really helps me. I don't like it for the ''cool'' factor. I need one. Can you tell me which engines for sure that it will work on? Something equivalent to the 2.5r will work.
ORIGINAL: proanti1
ORIGINAL: rooker
rip that crap of and get a recoil. i have had GREAT luck with pull starts, only two cords in 10 years, only 1 OWB. just dont pull start it like your life depends on it.
ORIGINAL: The_Shark
Personally, I don't mind the Ez-Starts at all... a hell of a lot easier than yanking on the thing, but they do get pretty irritating if you do not treat them with respect and keep them clean. Then again, I prefer an driving an automatic.
ORIGINAL: proanti1
As he said, he has a back problem.
ORIGINAL: The_Shark
Pop the car on a chest-high workbench/car hood/whatever while starting. Problem solved. Only muscles you need are the ones that pull your wrist up when you're set up that way.
Hell, I do that and I don't have a bad back.
FL
maybe for op, the less he has to pick up the car off the ground, the better. one must PUT the rc on the platform to restart.... i'm in a similar sitiation and own 2 traxxas nitros and one ten-t because of this.
