removing paint from polycarbonate/lexan bodies
using dot 4 brake fluid is by far the easiest and quickest way to remove paint from your polycarbonate/lexan body just pour and leave for 10 mins then wipe and keep repeating its that simple dot 3 dot 5 will not work
RE: removing paint from polycarbonate/lexan bodies
depending on the paint used I use plain ole rubbing alcohol to get off parma paints, pour it on a paper towel put the towel on the paint, and wait a min good chunk will wipe off easily. Bonus to the rubbing alcohol is the residue can be washed off with a little water, where the DOT 3 I hear the residue you can't remove.
ORIGINAL: firestone
dot 4 brake fluid will remove all types of paint used on your body
messn03 (02-15-2021)
dot 3 leaves a residue, however dot 4 does not. i use dot 4 to clean my hands after i'm done painting a new body.
anyone ever had a bad batch of paint?
rattled the can for a full minute, applied LIGHT coats of paint a few minutes apart. let them sit, i come back 6hours later and the paint shrunk and peeled and etched the body!
ruined a discontinued irreplacible body!!! it actually MELTED the body! and yes this was lexan paint.
I flip mine over backwards at 70mph and let er drag on the roof for a 100 yards, takes the paint right off! A bit hard on the lexan though I may add......
ORIGINAL: The_Shark
ORIGINAL: proanti1
It was probably not a Lexan body. Some early bodies were a type of acrylic, which is easily damaged by some paints.
ORIGINAL: The_Shark
