shock rebound issues - help
Old 08-26-2003 | 09:41 PM
Nitroaddict's Avatar
Default shock rebound issues - help
I just finished building my EB4 kit. My concern though, is that when i push down on the chassis, is sinks and then just stays there. it doesn rebound. could this be attributed to not enough shock oil? i thought i did it right, but maybe not. Even with preload clips installed, the shocks still dont have enough power to push the buggy back off the ground. Help
Old 08-26-2003 | 09:51 PM
I find that my RTR does the same thing (CEN TR4).
It shouldn't affect you when you're running though, since the air hitting the underside of your car helps to lift it back up.
Just MHO though
Old 08-26-2003 | 10:50 PM
There could be a few things attributing to this. Could be suspension bindings, spring too soft, using piston which are not enough holes, too thick oil.
Try this. Take out the shocks out of the car and compress them. To the extend by themselves? If so, check the arms of the car to make sure they are free. Try a harder springs, etc.
Old 08-26-2003 | 11:03 PM
dbow's Avatar
Default Springs
Dg is right, something is not correct on your shocks.
If you remove the shocks your arms should move up and down freely, if you raise one up and it stays there and does not fall you need to loosen them up a bit.
Keep in mind as you work that there should not be any slop in the arms either, they should move freely though.
Before you install your shocks be sure they operate properly, if you push a piston in it should rebound slightly but should not shoot out to full extension.
You should also be sure that you dont have any air trapped inside. If you operate the shock you will hear bubbles or little squeeks as you move it.
I always let my shocks sit for a bit with the caps off when I fill them, a few minutes and the bubbles usually go away.
keep in mind that the job of the shock itself is to manage the movement per the shock oil, not cause rebound. Thats the springs job.
With shocks installed you should push down and get some rebound depending on the amount of travel you have.
Dbow
