Futaba or Flysky radio?
I am getting my ARTR nitro in 2 days from now and need a radio system. I have been looking at a Futaba and Flysky which the Flysky would have to be ordered online to where I could go to a local hobby store and pick up the Futaba and have a good brand but pay a little more. Anybody have experience with either brand and if so, what are your thoughts?
RE: Futaba or Flysky radio?
I own 4 flyskys
Great radio IMO for the price
I've owned a lower end futaba (came with a RTR) its a good radio can't really say anything bad about it, just I wouldn't pay full price for one.
If you have the money to grab up a higher end Futaba, I would. Spektrum is also a pretty decent company, but if you lack the funds I would grab the FlySky GT3. They are a great radio, and worth way more than the asking price, IMHO, and i am not usually one to actively promote the "cheap Chinese crap", so take this as a good sign!
I have a flysky for my boat for 20 bucks i cant complain it gets the job done range is more than what i need ive never had a futaba myself but im sure there are upsides to the brand name products
the only downside to the fly sky systems is the horrible trigger, they are prone to breaking while braking, just order some extra triggers when you buy a controller. other than that its a great system and you can run extra models for only $7 a piece.
Yeh, I'm a big fan of the flysky for the money, but does it compare in any way to my Futaba radios? No. Just, no.
If you can afford a Futaba, that's the way to go, but also consider the future cost of receviers at 50 bucks each instead of 10 bucks each for the flysky.
As noted above, the plastics of the flysky do seem to have a reputation for being brittle, breaking triggers, wheels, etc. On the other hand I have a Futaba 3pk which is still going strong after at least 13 years, despite looking like road kill.
ORIGINAL: yakfish
In all the discussions I have seen, read or been apart of I have never seen anyone give a good reason to go with a futaba, spectrum or other higher end name branded radio system over the Flysky.
Just bought the Flysky from hobbyhot.com. Went to a local hobby shop and almost bought the futaba....just didnt impress me like the flysky does. Little things such as a charging port and a backlit lcd display the flysky has made me go for it. I probably wont be chargin it that much but its cool it can charge just in case.
My Feedback: (27)
ORIGINAL: Foxy
I disagree on futaba (not on spektrum). Futaba are so rock solid. You simply never hear anyone complain about them. Ever. Nobody talks about them at all in fact, which in this age of only writing about something when it has a problem, says everything without saying anything.
ORIGINAL: yakfish
ORIGINAL: The_Shark
a tire pin for a hex on a 1/10th and a tiny drill bit fixed that permanently
basically drilled where the nub was that held it in the radio, and replaced it with a pin off a 1/10th that I cut in half, and super glued in the trigger. Been holding up over 2 years
MI
Have a Flysky.
Wish I had a Futaba. Takes too much work to get the Flysky to work 'right'; polishing a turd is the phrase that comes to mind when I think of getting it reprogrammed.
ORIGINAL: porterdog
Have a Flysky.
Have a Flysky.
whats too much work to work "right"?
only one I had to get to work right was the Flysky GT3, and that was cause by default the factory settings are messed up in the one menu. And you have to change it on every model, but after that I've not had any issues that is the controllers fault (only issue was with a CC MM ESC, but thats castles half ass settings issues which is also with other brands and listed in the FAQ section)
the gt3b, and gt2 don't have that issue at all.
as for binding RX's find it easy, never had any issues.
My Feedback: (27)
ORIGINAL: porterdog
Have a Flysky.
Have a Flysky.
MI
I have the GT3b.
The first thing to really bum me out was the voltage regulator issue; a set of 8AA batts lasted mebbe 2-3 hours before the alarm sounded. Yeah, you can fix it- $10 for a new VR and maybe an hour of time, unless the crap antenna-wire solder job lets go and then you have to screw with getting that back together; total outlay at this point $45 not including time.
The nail in it's coffin (just ordered an Airtronics MT4) was the firmware. Expo is known to just not work, which is pretty lame, but the the straw that broke the camels back as it were was that dialing down the throttle EPA changed the neutral point and had other helpful bonus effects. When I drive, naturally I use 100% F/R. I used another 'model' to hold my 4yo's settings; he gets maybe 20-30% depending on the venue. The problem is that when I dial the REV EPA down the car cogs like it would if you veeerrrry slightly pushed the accelerator. As if that wasn't cool enough, reverse is completely non-functional. Admittedly, it can be reprogrammed; you can either buy the gear and do it yourself or send it out. Cost for that is probably about $30, again not including time (or downtime). At that point, I'd have $75 into a cheap chinese radio that's built to be disposable and has zero factory support. Just not worth it IMO.
I've read that there's a C version out; mebbe it's better. It's still disposable, and there's no support other than the user community.
ORIGINAL: porterdog
I have the GT3b.
I have the GT3b.
if you want to eliminate cogging at the low end of the throttle spectrum(what happens when you turn the EPA DOWN) use a sensored motor, and a sensored ESC, a radio will not change that when you are dropping your throttle to 20-30%
As for exp not working never bothered me seeing bashers rarely use it, now if someone was asking to get the gt3b for a race machine and needed expo I'd tell em to get a diff radio.
On the batteries I won't argue they are a hog(should see the original GT3's battery drain [:@]) why I swapped mine to a $10 3S 1800mah lipo pack (hell cheaper than a set of good AA's which were getting 5 hours). took me literally 3 minutes to modify it including removal of screws.
MI
ORIGINAL: SyCo_VeNoM
The cogging sounds like the RC's a BL sensorless setup...
When the throttle EPA is set to 100 there's no issue. You can make it cog with super low throttle inputs, but as you point out that's pretty much expected behavior, no?
The trouble starts when I turn down the EP of reverse to about 25%. At that point the truck cogs with no throttle input at all (neutral point has moved and is no longer sync'd to the physical neutral point of the trigger) and reverse doesn't work. You can eliminate the no-throttle cogging with throttle trim, but that doesn't do anything to restore reverse function.
There's a lot of happy users, but I've reached the point where the joy of a good price is vastly outweighed by the bitterness of poor performance.
Airtonics MT-4 if you can afford it. Your radio is your steering wheel - should feel solid and quality.
I couldn't afford the MT-4 just now, so got the cheap Airtronics Sport radio. So far so good. The Spektrum DX3S had horrible range issues on day one, plus felt flimsy, so I returned it.
MI
ORIGINAL: HerrSavage
Airtonics MT-4
Airtonics MT-4
Hell, I used to have dirtbikes; at one point Ihad 5 of them. I can bring both my and my sons cars up to full spec and spend a fraction of the cost of one bike.
Just ordered the Flysky last Tuesday and its already out for delivery exactly one week later from Hong Kong. I can say shipping was much faster than I expected so I will be breaking in my new nitro tomorrow. I'll leave feedback on the Flysky tomorrow. I just hope it was worth the wait!!
Still amazed it only took 7 days to receive this from Hong Kong!! Anyway this is my personal opinion.... I will be connecting the receiver to the rc tonite but so far, the controller feels much more durable than I had expected it to. The features seem to be nice and it has a little weight once you put batteries in. So far it feels and looks great. The only instructions were on a cd which are simple to understand. I will put it to the test tomorrow when I use it to break in and run my nitro.
