Velocity .17 Replacement
Old 09-03-2003 | 10:32 AM
Default Velocity .17 Replacement
Hey I have a Velocity .17 and I was wondering if anyone knew which engines would fit to replace it? Does is just bolt in? Do I have to mod my frame or anything to put in like a .15?
Mark
Old 09-03-2003 | 02:33 PM
Nitroaddict's Avatar
mark - all small blocks (.12 - .18) are the same size on the outside. any of these sizes will fit in without modifications. I would suggest the OS .15CV-X if u are on a budget, it will prodice about the same amount of power, but be MUCH more reliable. If u have a lil more to spend, go with the OS .15CV-RX - it will produce more power than 2 of the velocity's and also have the same famous OS reliability. The CV-X is about 90.00 and the CV-RX is about 130.00 both at tower hobbies.
Old 09-03-2003 | 10:55 PM
Billyman's Avatar
Nitroaddict is correct about the "small blocks". The mounting locations are the same for all.
I too have a velocity .17 and considering moving up to a .21. Since I'm a machinist and it’s nothing to throw the chassis into the mill, I may just do it although most say I’ll be overpowering my truck. Thing is, I don’t care. A clutch upgrade, a little different gearing……… Hey, I’m just having fun.
Old 09-03-2003 | 11:03 PM
Default OS .15CV-RX
I checked out the OS .15CV-RX and it says that the short crankshaft is is intended for like a rc10gt....Associated cars.
What difference does it make and will it still work in my Duratrax Overdrive ST?
Mark
Old 09-04-2003 | 03:00 AM
Billyman's Avatar
After further checking………
The bolt (screw) that goes through the spur gears and clutch would have to be a tad longer to make up the difference. The shorter crank snout is “very shorter”. And, just to let you know, when Overdrive ST’s first came out, they had .15’s.
Old 09-04-2003 | 11:34 AM
rustler - there are three types of shafts, all of which are available for the OS engines.
Short (SG) shaft - this is designed for the Team associated cars
Standard shaft - this is the shaft for your Truck
Pilot shaft - extended shaft, for use with kyosho, losi, ect
go with the standard shaft, and it will be a direct fit
Old 09-04-2003 | 09:23 PM
Billyman's Avatar
Aha!!
Prime example of one of the reasons I come here.
I’ve never done engine swaps in an RC car so I never read into it (I’ve never had to replace one period).
So thank you Nitroaddict, I learned something new today.
Old 09-08-2003 | 09:19 AM
Default RE: Velocity .17 Replacement
that will be 4 dollars.
Old 09-08-2003 | 06:26 PM
Billyman's Avatar
Can you just put it on my tab?
Old 09-08-2003 | 06:31 PM
im getting a .18 for my overdrive.
Old 09-08-2003 | 07:22 PM
What .18 are you getting??
How much of a difference do people notice between a .15 and a .18, are there .15 that are more powerful than a .18??
Old 09-09-2003 | 07:53 AM
rustler mark, almost every .12 race engine, such as the OS .12TR, the Novarossi lineup, the mugen MT12, are much more powerful than any .18 out there.
The only .18's that have any real guts are the Sirio and the Fantom FR. They put out about 1.3hp each. But the .15CV-r by os and the .12TR by os both put out 1.25, so hardly a difference. The Novarossi P5 puts out 1.65hp, now that will send ya for a loop
Old 09-09-2003 | 03:42 PM
Default SO....
So pretty much any engine that I replace my Velocity .17 with will be lots better??? If my engine is running fine, is it worth upgrading just for speed/power?
Old 09-09-2003 | 04:42 PM
Daddyo57's Avatar
My Feedback: (15)
Now that's just something that you will have to decide based on budget and go-fast factors.
Old 09-09-2003 | 08:56 PM
what who ever said .12 put out more powerr then .18 have you ever heards of the epic .18 1.8 hp at 39000 rpm now what a engine thats what im getting
Old 09-10-2003 | 06:31 AM
What size is the Novarossi P5? I'm going to go check some prices....thanks for all the help keep up w/the suggestions!
Mark
Old 09-10-2003 | 08:30 AM
corey - i said almost every .18 - not all of them - dont get your panties in a bunch
rustler - here is the new Novarossi:
http://www2.towerhobbies.com/cgi-bin...?&I=LXEPH4&P=0
I would STRONGLY recommend against that engine though, unless u are a professional racer - as it is almost impossible to tune, will not idle for more than about 10 seconds, and will require a strong ability to manipulate an engine - it is for racing only.
for a replacement of the velocity .17 - get the OS .15CV-R below:
http://www2.towerhobbies.com/cgi-bin...?&I=LXALL5&P=0
this engine still produces more than TWICE the hp of the engine u have now. is inexpensive, and has the famous OS Max reliability
Old 09-12-2003 | 06:47 AM
Addict,
Thanks when my velocity gets fried I will definitely look into that....until then I'll just bash around with the one I have......might save up some holiday money and then buy one
Mark
