STUPID SCREWS
Old 09-10-2003 | 07:07 PM
Default STUPID SCREWS
i was driving my xxx-nt today and i hit a crazy jump and rolled and it started to run really crazy loud. I checked temp it was at 248 so i shut it off. Took it to the side and after some tuneing i could not get the loudness to go down. So then i inspected the car mostly around the exhaust/header. I then noticed that i was missing one of the header screws!!! So it was losing compression and probably isnt good for it. So now i guess ill have to goto the lhs tommarow and see what screws they got that will fit. Because none of mine in my toolbox will fit
Old 09-10-2003 | 10:14 PM
Default RE: STUPID SCREWS
That happens alot especially in ready to runs, solution get two 4 /40 screws and two 4/40 nylon locnuts they make big size 4/40 and small 4/40 lock nuts ,you will want to purchase the tiny locknuts . put the screws through the muffler ,if you cut new threads its ok because your going to put the little tiny locknuts on end of screw & tighten .
Problem solved. Ps you might have to cut screws with dremel so screw dosent stick out so much , I had to anyway. They never came loose again hope this helps.
Old 09-11-2003 | 03:46 PM
studysession's Avatar
I had that happen to my NTC3 RTR. After I put in 2 spd then regeared it and many more hop-ups. It vibrated both exhaust screws and the screws that hold on the pull start and a few others. YES I use lock tite.
