slow
Old 09-22-2003 | 07:21 AM
Default slow
This forum loads slower than the old one. Is it just my pc/cable connection or do you find it slow.
Old 09-22-2003 | 07:45 AM
Default RE: slow
Yeah. Even the old site never loaded all that quickly for me. The new doesn't set any speed records.
Old 09-22-2003 | 10:32 AM
Default RE: slow
try running it lean.. and using some higher percentage nitro.. like 30% ..
Old 09-22-2003 | 10:54 AM
Default RE: slow
You know, i leaned it out until it was running on nothing but air but it's still a little slow.
Old 09-22-2003 | 11:13 AM
Default RE: slow
It would be running it on nothing but air!
You need to stick some copper additives in the fuel to help the signal flow.
Old 09-22-2003 | 11:34 AM
Rex2342's Avatar
Default RE: slow
Keep an eye on the temps too.Running to lean will cause the server to overheat and perform poorly.Try a new cooling head or maybe use different nitro with a higher oil content.
Old 09-22-2003 | 11:38 AM
Banned
Default RE: slow
if slow turn off dynamic menus in the header.
see the welcome panel on the forums as there is a link for this. you can also go to MyAccount and turn it off there. that will improve speed.
Old 09-22-2003 | 09:42 PM
Default RE: slow
Well, I guess he told yall! LOL[8D]
Old 09-23-2003 | 04:44 PM
Default RE: slow
You can also disable loading avatars, smileys, etc. All in the preferences.
