First experience is this normal?
Old 08-15-2017, 01:26 PM
  #51
ozzy1925
Originally Posted by RustyUs
That ballooning is pretty mild compared to the extreme "pizza cutters" that are out there. I like how, at the end of the video, the guy says he can't wait to take it out to do some speed runs. We see it all the time...off-road platforms converted into land missiles. I can't stand to think outcome with 4S; beadlocks, and high traction surface. Depending on motor, and gearing, I would not trust beadlocks to keep a hold of some rubber while an RC is traveling faster then 30mph.
Just my $0.02
thanks I will see if they handle or not very soon well as I measured the hole to hole length is 80mm I wond will happen if I buy 92mm hole to hole shocks? Because ordered these shocks
http://s.aliexpress.com/naAjQrM3
[img]webkit-fake-url://a8c29f81-2bf9-4e76-b898-91ff1ed0976b/imagepng[/img]
Which are 80mm hole to hole but when I install these they couldn't handle the weight of my car and the car almost touch the ground so i need better shocks I find bigger ones but they are 92mm hole to hole and overall 100mm
http://s.aliexpress.com/6Zrey6ZV
do you think will this work better?
also there are redcat brand shocks Redcat Racing Upgrade Shocks for Blackout XT,XB,SC (2 Piece) https://www.amazon.com/dp/B01CEG9MVU/ref=cm_sw_r_cp_api_IH2Kzb6Q7V0RV
but theses are very expensive and look same quality as the one I linked
Old 08-17-2017, 08:40 AM
  #52
EXT2Rob
EXT2Rob's Avatar
Shocks don't support the weight of the car, springs do. The shock slows the spring action. You need stiffer springs.
