Spacer for rear
Spacer for rear
Hi there,
I had a question if anyone has run into this problem before? I just put new wheels on my car and they are rubbing on my lower shocks. Does anyone make a spacer that I can add to push the tires out a little further? I looked online and just seems to be adapters for trucks to widen there stance. Any suggestions greatly appreciated as always.
Probably easier to move the shocks to the inner holes, but if your car is using 12mm hexes then you can use these spacers here too, just be sure you understand that changing your track width will reduce traction:
https://www.avidrc.com/product/5/acc...cessories.html
keep in mind that the more vertical you stand the shocks up, the more traction you create on that end of the car... so if you move the lower hole inside, then you want to move equal distance on the upper hole to maintain the same traction, otherwise your front end might start to push in tight corners.
I just tried moving the shocks to the inner hole but now it seems the rims are rubbing on the suspension arm on the front and the rear.....going to defintly need to space out a couple of more mm or look for different wheel options.
I found these on Ebay https://www.ebay.com/itm/323053600510 will try them out will give me an extra 2mm.
