Rc car won't move nor turn!!! Help!!
After a long time of not using my 1/10 Carisma Touring RC Car, it has recently stopped working. There is no sound or any sign of life. I believe water has damaged some electric part as the last time I drove it was in the wet, recklessly. The question is, what part do I need to replace? Motor, ESC, Reciever? etc.
Please help!!!
Car model: Carisma M40S.
Also the servo is new and upgraded and has no problems. Help!
Please help!!!
Probably going to be the receiver or speed control. Simplest way to find out is change each out one at a time. If you don't have any spares and don't know anybody that might have a spare, a hobby shop would probably be your best bet.
Some more Help!
Thanks for your help. So let's say I am going to change the receiver, what am I supposed to purchase? My Transmitter works perfectly. Do I have to change the Transmitter as well? And if yes then can you show me an example of such?
Thanks.
Thanks.
I don't know what receiver or speed controller you have. Look around in here and see if you see yours. A lot of their stuff is out of stock because of the shutdown. Other shops might have parts as well. I just googled the car and all kinds of stuff popped up. If you have a good local hobby shop they could probably tell you what you need to buy instead of buying everything one at a time.
https://www.amainhobbies.com/carisma/b2650
Thanks, but the receiver is out of stock everywhere. But also I do not wish to have this receiver equipped on my car anymore as it is not waterproof.
How can I change the receiver without changing the transmitter?
Or if this is not possible then is it possible if I could just purchase a Flysky FS-GT2? (orange transmitter).
That transmitter on eBay comes with a receiver. Is it not possible to just install that and run it?
You can buy a new receiver like you already have and link it to your transmitter when they come back in stock. You can get a flysky and put in the car. Either will work as long as the receiver is the problem. If it's a speed control problem you still have your problem and have spent 50 bucks. Do you have a receiver battery pack? If you do you can plug it into the receiver where the speed control goes. If the steering works with a battery plugged in you have a bad speed control. You may have to wait till this virus scare is over to get any parts. Good luck
But you can change the receiver w/o changing the transmitter. They come as a set. As long as the replacement one is also of the same brand, you're good to go.
Wow thanks man. That was enough information to satisfy me on this problem. I sure will check it out. Also nice channel, you have the confidence which others don't in your videos. Keep it up!
ps. I have my own channel with 3.6K subs and 3 Million Views.
