ESC not powering motor
Hello,
I am looking for some help with some new setup.
I have a DX5C Smart 5-Channel DSMR Transmitter with SR6100AT Receiver. I bought the Dynamite WP AE-5L Brushed ESC LED Port Light w/IC3.
When I hook up the ESC to the receiver, and power with battery, I am able to bind the receiver to the transmitter. The servos function, however there is no power to the motor. The ESC has a continuous flashing red light too!!!
How do I initialize the ESC so that power goes to the motor? The motor does work - I connected it directly to the battery to see if there is life - and there is.
Thanks so much in advance for any help with this!!
Bradley
Bradley
also make sure the ESC is plugged into the correct slot on the receiver. ESC goes into slot 2. steering servo goes into slot 1. may also want to double check that the ESC plug is plugged into the receiver the correct way and not upside down.
Thanks for the response @bill_delong
@suburban_hooligan, I have a servo that is inserted into the throttle and the ESC is inserted into a different slot. Does this make a difference, and is this my issue? The servo moves a gearbox with three gears. You seem to be onto something here!!!
Follow up - I plugged the esc into slot 2 as above, and now the motor works!!!
However I have this in a semi truck that has a throttle servo which moves the gearbox. Given this scenario, how do I get the gearbox and motor to move?
bill_delong (01-25-2024)
I figured it out!!!
Based on a youtube video I watched, and the responses from above, the esc goes into the throttle. The gearbox servo connects to an AUX port and is setup on a switch that has 3 travel settings!!!
I am so excited to get this thing running now!!!
