Well some super glue (not CA) leaked onto my servo and when I trie to remove the screw that has the spacer /moount it won't come off! I think super glue got in the threads and/or there is some in the head of the screw![:@][:@][:@][:@] How do I get it off?
once again - the famous word - asetone! or otherwise known as fingernail polish remover. it is the same ingredient that is in nail polist remover. should work just fine, but test a spot first to make sure it wont injure the plastic servo parts.
Thank you soo much!
I really want to get my car running soon and I need this servo.
I really want to get my car running soon and I need this servo.Senior Member
People call it super glue remover. You can get it where you bought the super glue
Paint Thinner.
Just put it on a little papper towl and then rub it on, let it sit for about 5 min and it will come off like icing!
I hope this helps!
I hope this helps!
super rusty - paint thinner works? wow, i never tried that before, i have tons of that laying around, ill have to give it a shot!
They make this stuff called De-Bonder.I've used it a few times to remove my tires from the rims.It work very good.I've tried acetone but the De-Bonder seems to work better.
yes, paint thinner works! But you have to be carefull were you put it! It gets in your Servo your screwed!
Dab "Acetone" with a q-tip on the affected area. Several
times will begin to soften the glue. I dont even want to
know how you got glue in the servo, but next time make
a small puddle of glue on something disposable, not paper,
and use the tip of an exacto to apply it.
