Tuning Problems!! Need help!
Old 11-16-2003 | 06:56 AM
Default Tuning Problems!! Need help!
I don't know why, but my tempurature is rising non stop with the McCoy MC9 and with the MC8 the temperature is around 250 F (5 - 5.5 turns out!!). And the other trouble I have is when I put 1/4 throttle, it runs fine but when i go above that it will slow down, sound different and eventually shut off! If the problem is the LSN tuning.. please tell me what people mean by starting at flush? I seems like i can keep on turning it.
Btw... when it seems that I have the correct tuning, the tempurature goes over 250 and sometimes 300 idling + running!!
I am using Byron's 25% fuel and an Ofna Hyper 7 8port with pullstart.
Old 11-16-2003 | 07:03 AM
Default RE: Tuning Problems!! Need help!
Flush means that the LSN is flush with the outside of the body of your carb. So unscrew it till it seems flush to the end of your carb.
Old 11-16-2003 | 07:13 AM
I forgot to mention that I'm in Thailand so it should be hotter than the states[>:]
Old 11-16-2003 | 07:31 AM
Did you get what I was saying about Flush?
Pretend the two top and bottom letters are your throttle body and the middle is you LSN
___l
_l ..........."LSN Screw" Might be a little lean
___l
___l
__ l ..........."LSN Screw" Flush probably factory setting
___l
__l
____l ..........."LSN Screw" Way rich
__l
Old 11-16-2003 | 08:09 AM
thanks, I'll try it 2morrow... How bout my problem with tempurature? do I have to compromise with the climate here for like 6 turns out on the HSN?! or do I need some kind of glow plug? or is it the 25% fuel making it heat up so much?
Old 11-16-2003 | 10:06 AM
Billyman's Avatar
Your temps are normal. The temp is always higher when idling (there’s no air moving through the heat sink).
Old 11-16-2003 | 10:26 AM
MiCkLe207 the sound that you here when you idle is most likly the engine loading up from being too rich. How long does it take before the sound changes? I have my idle to about 8 seconds before it loads up. If your loading up around 3 seconds or so that is why the engine dies after you punch it from idle.
Old 11-16-2003 | 11:16 AM
I don't think mine loads up, but it idles for a long time!
btw, after 2-3 tanks i noticed that i could even pour out some oil in the exaust pipe!!
