Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Car General Discussions
 Using a tank for compressed air vs. a compressor??? >
Old 12-31-2003 | 02:58 AM
nathanstl's Avatar
Default Using a tank for compressed air vs. a compressor???
Ok I really want to start using some compressed air to help clean my rc cars when I'm done bashing, but really don't want to spend the cash on a air compressor just for this purpose. Could I use a small air tank and just fill it up at a service station every once in a while or would that just run out to quick? Even if it would be enough to clean one car it would work for what I want it to do.
Old 12-31-2003 | 07:05 AM
RaZ_Tx's Avatar
Default RE: Using a tank for compressed air vs. a compressor???
that idea realy isnt worth the trouble you can get a 1 gallon compressor for under $100 new (sears hardware stores has one here in houston for $89) and cheaper used if you check pawn shops
Old 12-31-2003 | 03:54 PM
The tank Idea won't work. You'll only get about 15 seconds worth of air out of a 5 Gal portable tank. I belive that Home Depot has a small unit for $89 well worth it though, Compressed air is the absolutlely best way to clean em up after a day out.
Old 12-31-2003 | 07:47 PM
nathanstl's Avatar
I've got pm's from others that say it will work and work fine. Also a $18 tank is a big difference vs. an entry level small compressor for $100 so I think it is definitely worth a try. I've asked a few local people now and they say it should be good for at least 1 car cleaning. Have you guys actually tried this? What psi did you fill the tank to and what size tank.
Old 01-01-2004 | 02:17 AM
I have a 25 GAL tank on my compressor. I can tell you that it is just enough when I start with a pressure of 125 PSI on the tank.
There is a big difference between $18 and $85 but in the long run you'll thank yourself for buying it. However if $85 is just way out of your budget, I have 2 kids under the age of 5 so belive me I understand how tight money for the big kid toys can be. Go ahead and get a 5 Gal tank until you've got the cash to upgrade. My brother had a setup like the one you're describing that he fills at home with a $25 compressor he bought a Lowes. It works OK but he spends more time rechaging it than actually using it.
Old 01-02-2004 | 12:41 AM
nathanstl's Avatar
Yeah I went out tonight to get the tank, but then saw a decent smal compressor next to it for 89.95 and I thought how much more convenient that would be, but then I think to myself if I'm going to buy a compressor it might as well be a decent size one so I can use it for other stuff like air tools! Go figure! So now I'm thinking of spending $200! Oh well I tried to save some cash, but it never works
Old 01-02-2004 | 02:03 AM
Buying an air compressor is one of, if not the best investments I've ever made in tools. My only regret is that I didn't buy a bigger one. My 3 HP Campbell Hausfeld compressor just doesn't quite cut it when I try to use my DA sander or a die grinder for extented periods. Oh well I've had it almost 15 years and I still haven't managed to wear it out so I can't justify buying a new one. One of these days I'd sure like to get a 8HP with a 60 Gal tank.
I know $200 is a lot of cash to spend to clean your RC car. But I promise you will find so many uses for it. Compressors have really come down in price too. I spent $375 on mine in 1988 dollars.
Good luck
NITROZ
