Priming engine
Old 01-09-2004 | 04:34 PM
SqueedilySpooch's Avatar
Default Priming engine
Well i know how to prime an engine but only for pull start one is it the same way for a non pull start cause i don't really know. do you hold the stinger or whatever and put it on a starter box then your done. please help
P.S. no manual on engine or for starter box i guess i lost it
Old 01-09-2004 | 08:13 PM
Default RE: Priming engine
Yes, you can prime it the same way as a pullstart OR you can hold the stinger and put it on the starter box but I don't like that way cause your turning over the engine with no oil in it and also it is easier to flood the engine. I like pinching the pressure line and snaping the fuel tank lid. It is fast and also does no harm to the engine.
Old 01-12-2004 | 08:53 PM
soccerismylife's Avatar
It doesn't matter if it is pull or not except that method 2 ibnvolves a starterboxc or pull starter.
1.Push primer button
2. Hold stinger and either pull the starter or turn the starterbox over a couple times.
