Can't remember...
Old 05-30-2002 | 07:01 PM
Default Can't remember...
Changing the pinion gear on an electric car effects what, does a smaller, i.e. less teeth increase ___________? decreas _________? I used to know, but I can't remember anymore.
Bill
Old 05-30-2002 | 07:26 PM
JohnVH's Avatar
My Feedback: (38)
A smaller pinion will decrease speed, but make more low end power-torque and increase run times on electrics
A larger one will increase top end but decrease bottom end power. And decrease run times on electric
Old 05-30-2002 | 07:35 PM
A bigger pinion will also make the motor run hotter.
Old 05-30-2002 | 08:36 PM
Default Thanks
Thanks guys, that clears it up, it's been a while.
Can either of you guys explain how to determin the actual gear ratio for a given setup. If you make the main gear on say a TC-3 smaller or larger and/or the pinion gear what the effects would be?
Thanks again,
Bill
Old 05-30-2002 | 09:57 PM
JohnVH's Avatar
My Feedback: (38)
Kinda be the opposite, the larger the spur gear the slower you will go, while the smaller the spur the faster, but with consequences.
Old 05-30-2002 | 11:33 PM
Default Thanks
Makes sense...
