Ofna Aluminum Fuel Filter PROBLEMS
Old 04-24-2004 | 04:57 AM
tegwin's Avatar
Default Ofna Aluminum Fuel Filter PROBLEMS
I installed my new fuel primer and filter onto my savage and squeezed it, the fuel flows throgh it okay, but the metal part with the filter in it keeps popping out of the rubber section when i squeze causing fuel to spray out.
What can i do?~
Old 04-24-2004 | 06:13 AM
Mastec's Avatar
Default RE: Ofna Aluminum Fuel Filter PROBLEMS
Can you put a zip tie around it?
Old 04-24-2004 | 06:16 AM
tegwin's Avatar
I was thinking about using a zip tie, but if there is even the tiniest leak then the truck will run lean.
