Differential question Evader ST
Old 07-14-2004 | 02:20 PM
Default Differential question Evader ST
I just took apart my transmission and lubed everything up and it runs smooth but I placed the screw you tighten the differential with on the left instead of right. Will it work on both sides or just the right?
Thanks alot, Shredder[>:]
Old 07-14-2004 | 02:32 PM
Default RE: Differential question Evader ST
it should work on both sides
Old 07-14-2004 | 03:34 PM
Mastec's Avatar
I believe if you put it on the left side it will loosen itself because the left wheel is going counterclockwise, which is the direction to remove screws and nuts. Thats why they have them on the right.
Old 07-14-2004 | 03:49 PM
RayRayraycer20's Avatar
That is exactly right!!! ^^^^^^^^^^^^
Old 07-15-2004 | 05:46 PM
cjg's Avatar
cjg
I find it interesting that Losi puts theirs on the on the left side. What is the difference?
Old 07-16-2004 | 03:11 PM
evaderguy89's Avatar
Hi,
I have a Duratrax Evader st. I modified the truck and have a Trinity Speed Gems 15T Titanite motor. I have about 8 runs on the truck. The motor is now squealing and i was told that i should get commutator drops, motor spray, and/or bearing oil. What ones do you think i should get?
Old 07-16-2004 | 03:15 PM
Mastec's Avatar
bearing oil and motor spray
Old 07-16-2004 | 09:28 PM
cjg's Avatar
cjg
definitely motor spray and bearing oil to clean and lubricate.
