4 Tec Problems
Old 08-13-2002 | 12:25 AM
Default 4 Tec Problems
Electric 4 Tec Ok Guy's the engine and car runs fine with engine out of car. When the engine is in the car it clitches and goes crazy. I have checked everything and can't find a problem. Thanks for any help, Dave
Old 08-14-2002 | 01:21 PM
dbow's Avatar
Default glitch
You need to look for metal to metal contact or possible loose metal to metal contacts.
also, could be your rec. ant. running across metal parts. Check the pipe and exhaust as well.
I would start troubleshooting with the radio on while its glitching and start taking the car apart. Problem area should surface at some point.
Dbow
Old 08-14-2002 | 03:52 PM
Default Electric 4- tec
I have electric 4- tec. I changed everything over to Pro 3 and everything works great . So i will just take the 4-Tec apart and rebuild it .
