engine
Old 10-30-2004 | 01:33 PM
q8murder's Avatar
Default engine
ok every time i start my car it just goes full throtle and the carb is just opened i mm and the fuel was fresh can any1 help me[:@][&o]
Old 10-30-2004 | 02:47 PM
Default RE: engine
Sounds like a radio problem, without starting the car turn on both the reciever and the transmiter and see where the throttle servo is in the idle position and go from there.
Old 10-30-2004 | 03:03 PM
Nitro Rustler Racer's Avatar
Default RE: engine
o do this, with out turning on your radio or reciever start the truck if it goes full on ilde somthing wrong with the engine. but these engine when you prime them you get alot of fuel in the engine and when you start the engine revs high even on idle to burn the fuel out when you start try to start it and if it goes to full let is do it for like 3 secs and if it dont stop then its somthing with the rado
Old 10-30-2004 | 05:56 PM
q8murder's Avatar
Default RE: engine
dude i cheked it still the same problem
Old 10-30-2004 | 08:27 PM
Default RE: engine
hmmmmmm, this is what you do, take the servo saver of the servo. make sure the carb is at idle. if its not when you close it all the wya than adjust the idle screw until it is. then turn on you radio and reciever and set the throttle trim that its at 0 or the middle on our radio. then while the carb is at idle the servo saver back onto the servo making sure the carb is at idle, this is done with the engine not running
Old 10-31-2004 | 03:06 PM
q8murder's Avatar
Default RE: engine
.....im kinda newb so if u can just tell me what is a servo saver????
Old 10-31-2004 | 03:18 PM
Default RE: engine
its that little black control arm on the servo that the rod from the carb to the servo connects to
Old 11-01-2004 | 10:04 PM
SS Nitro's Avatar
My Feedback: (-1)
Default RE: engine
It's one of these
1)servo horn( one the servo) is not set a 90 degrees when gear and car is turned on.
2)Batteries are dead
idle screw is not set flush with the lsn( low speed needle)
Old 11-01-2004 | 10:27 PM
Default RE: engine
ya or that, but if the servos move then the batteries should be ok
Old 11-06-2004 | 01:26 PM
q8murder's Avatar
Default RE: engine
i cheked all that and the problem still stays and i send 5 e-mails and no replyes so is the engine defected???? did any1 ever try to contact orion??
Old 11-06-2004 | 01:35 PM
Default RE: engine
could the engine be really lean?
Old 11-06-2004 | 03:38 PM
q8murder's Avatar
Default RE: engine
my bad the servo horn thing was not 90 degrees i adjusted it but did not start it yet but will in 2 hours
