How do I protect the underside of my graphite chassis?
CA
I have a new graphite chassis, its not the molded kind. and i dont want to scratch it all up. what can i do to protect it?
WA
Don't drive on gravel or rocks. Drive on nice dirt tracks. That will help some. I wouldn't worry about it. Drive it like you stole it and have fun!
CA
well, that was helpful. It's an onroad car by the way, so gravel and rocks is way out of the question.
My Feedback: (158)
Ok, Sorry, I'm a recovering "ah"
How about this
Buy about 10-12 titanium button head screws, put them all round the parimiter of the chassis, then when you over brake or over roll or bottom out the screws hit first before the CF
The Ti will shoot some great sparks too, really cool when running at dusk
How about this
It sounds like you are a prime candidate for a peel and stick film. Personally, I use a teflon cloth tape on the bottom of my on-road cars.
Here's a link to Team Associated's chassis protective film at Tower Hobbies:
http://www2.towerhobbies.com/cgi-bin...?&I=LX2553&P=7
Sorry I can't really help here, but what's the point of protecting the underside of the chassis? Even if it's for show, the car is usually right side up, not vice versa..
For me, there are 3 reasons to protect the chassis:
(1) teflon cloth or mylar tape has less resistance when scraping the ground. This results in faster lap times
(2) when you drag your chassis on pavement, you wear it down. Over time, this will make it substantially weaker and prone to flex, crack, and fail
(3) it looks better when your friends and fellow racers pick it up and check it out.
It lasts much longer than you might think. I ran my HPI RS4 pro for 2 seasons of carpet racing plus an HPI challenge (parkinglot where the chassis would bottom out several times per lap), and the teflon cloth tape still looked new when I sold the car a few years ago.
I've seen guys at my local dirt track run a full season with the mylar film (from associated) before replacing it (chassis still looked like new when they peeled it off).
My Feedback: (18)
They used to sell this clear sticky backed vinyl stuff, its been a while since Ive seen it for sell, so I dotn know if its even made anymore. but you could look at the office supply stores and maybe an auto paint shop. I think some people use it to make custom masks (like flames and whatnot) when painting small things.
If you cant find that, Ive seen this other stuff sold as a scratch protector for guitars, [link=http://www.stewmac.com/shop/Pickguards/Pickguard_materials/Clear_Pickguard_Materials.html]check it out[/link] see what you think. It comes in 10"x13" only but I think it should be big enough to do a 1/10 scale chasis.
take a 2 liter bottle and cut the size you need for the chasi you may need 2 bottles. then with the screws for the tranny or steering or somthing attach it, works great
Tower Hobbies still sells the mylar film (see my above post with the link). The teflon cloth tape I use is very inexpensive per application, but the inital purchase cost of the roll can hurt some budgets ($250+ per roll). The good news is a roll should last a lifetime
As for titanium screws or plastic, if you're racing, this raises you center of gravity and will adversely affect handling.
.As for titanium screws or plastic, if you're racing, this raises you center of gravity and will adversely affect handling.
My Feedback: (18)
That would work fine, but then you'd either have to glue it on or screw it on, you probobly wouldnt want to glue it on becasuse then it would hard to get off, and if your putting it on to keep a chasis looking nice I dont think youd want to screw it on either.
There is nothing you can do. The Chasis is going to get scratched one way or the other. Nobody cares about the bottom of your chasis anyway. As long as it does crack and holds all of your internal components its good.
Please resist the urge to curse, flame, degrade, insult or embarrass someone in your post. We encourage the free flow of your ideas, but believe that they can be communicated (and received) much more effectively if you keep things civil. If you have to vent, take it offline. We carefully monitor posts and will ban individuals who engage in offensive conduct within the forums. Thanks. (RCU Policies)
If you don't have anything constructive to say then don't say anything!I like the idea of the protective film. The lexan might work aswell. Where could I get a thin sheet of lexan?
CA
ORIGINAL: potatoe_bird
